I can rosmake, ant, and ant debug android_tutorial_pubsub without error. I can install the .apk on my android phone just fine, but when I attempt to run the app, it crashes immediately.
I ran a adb logcat to locate the error. I received a number of errors. They are the same errors received during my attempts to run the app in eclipse.
Do I need to go through an extra build process in order to get a complete app on the phone?
Any help or guidance would be greatly appreciated.
The logcat of errors follow:
01-19 23:08:00.520 2154 2154 E AndroidRuntime: FATAL EXCEPTION: main 01-19 23:08:00.520 2154 2154 E AndroidRuntime: java.lang.Error: Unresolved compilation problems: 01-19 23:08:00.520 2154 2154 E AndroidRuntime: The import org.ros.android.MessageCallable cannot be resolved 01-19 23:08:00.520 2154 2154 E AndroidRuntime: The import org.ros.android.RosActivity cannot be resolved 01-19 23:08:00.520 2154 2154 E AndroidRuntime: The import org.ros.android.views cannot be resolved 01-19 23:08:00.520 2154 2154 E AndroidRuntime: The import org.ros.tutorials.pubsub.R cannot be resolved 01-19 23:08:00.520 2154 2154 E AndroidRuntime: RosActivity cannot be resolved to a type 01-19 23:08:00.520 2154 2154 E AndroidRuntime: RosTextView cannot be resolved to a type 01-19 23:08:00.520 2154 2154 E AndroidRuntime: The method onCreate(Bundle) of type MainActivity must override or implement a supertype method 01-19 23:08:00.520 2154 2154 E AndroidRuntime: RosActivity cannot be resolved to a type 01-19 23:08:00.520 2154 2154 E AndroidRuntime: R cannot be resolved to a variable 01-19 23:08:00.520 2154 2154 E AndroidRuntime: RosTextView cannot be resolved to a type 01-19 23:08:00.520 2154 2154 E AndroidRuntime: RosTextView cannot be resolved to a type 01-19 23:08:00.520 2154 2154 E AndroidRuntime: R cannot be resolved to a variable 01-19 23:08:00.520 2154 2154 E AndroidRuntime: RosTextView cannot be resolved to a type 01-19 23:08:00.520 2154 2154 E AndroidRuntime: RosTextView cannot be resolved to a type 01-19 23:08:00.520 2154 2154 E AndroidRuntime: RosTextView cannot be resolved to a type 01-19 23:08:00.520 2154 2154 E AndroidRuntime: MessageCallable cannot be resolved to a type 01-19 23:08:00.520 2154 2154 E AndroidRuntime: The method call(String) of type new MessageCallable<String,String>(){} must override or implement a supertype method 01-19 23:08:00.520 2154 2154 E AndroidRuntime: The method init(NodeMainExecutor) of type MainActivity must override or implement a supertype method -19 23:08:00.520 2154 2154 E AndroidRuntime: RosTextView cannot be resolved to a type 01-19 23:08:00.520 2154 2154 E AndroidRuntime: The method onDestroy() of type MainActivity must override or implement a supertype method 01-19 23:08:00.520 2154 2154 E AndroidRuntime: RosActivity cannot be resolved to a type 01-19 23:08:00.520 2154 2154 E AndroidRuntime: 01-19 23:08:00.520 2154 2154 E AndroidRuntime: at org.ros.android.tutorial.pubsub.MainActivity.(MainActivity.java:21) 01-19 23:08:00.520 2154 2154 E AndroidRuntime: at java.lang.Class.newInstanceImpl(Native Method) 01-19 23:08:00.520 2154 2154 E AndroidRuntime: at java.lang.Class.newInstance(Class.java:1409) 01-19 23:08:00.520 2154 2154 E AndroidRuntime: at android.app.Instrumentation.newActivity(Instrumentation.java:1021) 01-19 23:08:00.520 2154 2154 E AndroidRuntime: at android.app.ActivityThread.performLaunchActivity(ActivityThread.java:1610) 01-19 23:08:00.520 2154 2154 E AndroidRuntime: at android.app.ActivityThread.handleLaunchActivity(ActivityThread.java:1716) 01-19 23:08:00.520 2154 2154 E AndroidRuntime: at android.app.ActivityThread.access$1500(ActivityThread.java:124) 01-19 23:08:00.520 2154 2154 E AndroidRuntime: at android.app.ActivityThread$H.handleMessage(ActivityThread.java:968) -19 23:08:00.520 2154 2154 E AndroidRuntime: at android.os.Handler.dispatchMessage(Handler.java:99) 01-19 23:08:00.520 2154 2154 E AndroidRuntime: at android.os.Looper.loop(Looper.java:123) 01-19 23:08:00.520 2154 2154 E AndroidRuntime: at android.app.ActivityThread.main(ActivityThread.java:3806) 01-19 23:08:00.520 2154 2154 E AndroidRuntime: at java.lang.reflect.Method.invokeNative(Native Method) 01-19 23:08:00.520 2154 2154 E AndroidRuntime: at java.lang.reflect.Method.invoke(Method.java:507) 01-19 23:08:00.520 2154 2154 E AndroidRuntime: at com.android.internal.os.ZygoteInit$MethodAndArgsCaller.run(ZygoteInit.java:839) 01-19 23:08:00.520 2154 2154 E AndroidRuntime: at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:597) 01-19 23:08:00.520 2154 2154 E AndroidRuntime: at dalvik.system.NativeStart.main(Native Method) 01-19 23:08:00.528 1298 1464 W ActivityManager: Force finishing activity org.ros.tutorials.pubsub/org.ros.android.tutorial.pubsub.MainActivity -19 23:08:00.528 1298 1464 W ActivityManager: Force finishing activity com.motorola.blur.home/com.motorola.blur.apps.AppsActivity 01-19 23:08:01.036 1298 1310 W ActivityManager: Activity pause timeout for HistoryRecord{4095ac38 org.ros.tutorials.pubsub/org.ros.android.tutorial.pubsub.MainActivity} 01-19 23:08:01.098 2000 2000 W WidgetAidService: BroadcastReceiver onReceive called 01-19 23:08:01.098 2000 2000 D WidgetAidService: ACTION_HOME_SCREEN_CHANGED - 3 01-19 23:08:01.223 1298 1847 I ActivityManager: No longer want com.motorola.cmas (pid 1805): hidden #21 01-19 23:08:02.286 2154 2154 I Process : Sending signal. PID: 2154 SIG: 9 01-19 23:08:02.372 1298 1443 I ActivityManager: Process org.ros.tutorials.pubsub (pid 2154) has died.
Originally posted by Srogacki on ROS Answers with karma: 74 on 2012-01-19
Comment by Srogacki on 2012-01-20:
thanks for the help. I went back to ensure that the android_gingerbread package was not only being referenced, but also included in the app installation.
The errors in eclipse show up as build and compile errors prior to running, but the app will still build outside of eclipse.
I am using SDK tools rev 16, and I have the platform installed for versions 9, 10, 13, and 15. My device is running 2.3.3. When I say "run in eclipse" I mean selecting "run as android application" which should install the app on my device and run it.
Comment by ahendrix on 2012-01-19:
Which version of the android tools are you using? What version of android are you running on your device? When you say "run in eclipse" do you really mean "run in the android simulator"?
I explicitly included android_gingerbread on the build path of android_tutorial_pubsub instead of just letting eclipse grab references from the open project. This seems to have solved the problem. I ran the program out of eclipse onto my device. It took a little while, but after a minute or two it showed up on the device.
Originally posted by Srogacki with karma: 74 on 2012-01-20
