Linking CXX executable gazebo-non-ros
libgazebo_server.so.0.10.0: undefined reference to clock_gettime' collect2: ld returned 1 exit status make[4]: *** [server/gazebo-non-ros] Error 1 make[4]: Leaving directory
/home/klapfer/ros/stacks/simulator_gazebo/gazebo/build/gazebo/build'
make[3]: *** [server/CMakeFiles/gazebo-exec.dir/all] Error 2
make[3]: Leaving directory /home/klapfer/ros/stacks/simulator_gazebo/gazebo/build/gazebo/build' make[2]: *** [all] Error 2 make[2]: Leaving directory
make[1]: *** [installed] Error 2
make[1]: Leaving directory `/home/klapfer/ros/stacks/simulator_gazebo/gazebo'
CMake Error at CMakeLists.txt:32 (message):
Build of Gazebo failed
I just changed computer this morning and when trying to compile the gazebo_simulator I get this error. It is computer depended, but I have no clue where the error comes from.
I hope I can find some help here. Thank you all in advance.
Reinhard
Originally posted by ReiniK on ROS Answers with karma: 84 on 2012-02-28
Comment by ReiniK on 2012-02-28:
Note: I am tryng to compile the latest version taken from
https://code.ros.org/svn/ros-pkg/stacks/simulator_gazebo/tags/electric/
