I would like an affordable beginner's robot that can be used for learning and exploring ROS. The ones that are compatible with ROS mentioned on the ROS website, are a little out of my budget at the moment. Are there any cheaper alternatives?
A simple mobile platform would be sufficient to begin with and then I can add more components as my proficiency with ROS increases. I tried search for other similar questions on the site, but it turned up naught...
The iRobot create would not be an option because I am from outside the US.. unless, they changed the rules that allows foreigners to buy iRobot creates..
Thanks
Originally posted by cassander on ROS Answers with karma: 121 on 2012-02-24
Where are you located? You might be able to work off of a Roomba instead of a Create.
For example, I think that's what Turtlebot EU does. (Though they're not accepting orders currently).
Originally posted by Murph with karma: 1033 on 2012-02-24
Comment by cassander on 2012-02-24:
Im in Asia. Either way, a turtle bot is too expensive I feel. I would simply be happy with a mobile platform without any other sensors. Something with motors, wheels and a base that can be controlled using ROS...
Comment by Peter Heim on 2012-02-24:
If you use a serializer MCU and 2 gearmotors with encoders, wheels will cost you about $250. But you have to assemble it your self, Pirobot (http://www.ros.org/wiki/pi-robot-ros-pkg) has ROS software to make work
Comment by cassander on 2012-02-25:
By a "serializer MCU" you mean a microcontroller that has a serial port and can communicate serially with the main computer?
Comment by Peter Heim on 2012-02-25:
Yes but most use a USB port (http://www.roboticsconnection.com/p-16-serializer-robot-controller.aspx) With the above setup you will have a basic robot that can be controlled with ROS the built in motor driver has enough power to carry a small laptop
How about the arduino? Would I be able to do the same thing with arduino? Because, it is a lot cheaper and there is a "rosserial" stack with a "rosserial_arduino" package which enables communication between the arduino and ROS. Ofcourse, I will probably have to buy a separate motor driver...no probs
Yes here is a link (http://www.hessmer.org/blog/) my own robot is based on a lot of this code here is the link to my blog (http://escaliente-robotics.blogspot.com.au/) it's a holomonic rob0t and uses a arduino mega
Comment by Pi Robot on 2012-02-26:
Hi @cassander. The Serializer MCU is now called the Element and is sold by cmRobot at http://www.cmrobot.com/#!element-.net.
