Hi, I want to use Tabletop_objects_detector with a kinect camera manually without using an arm and manipulation stack. but i don't know how can i set the object type which is tabletop_object_detector should be recognize! as i considered the pr2_object_manipulation_stack there is a service in tabletop_object_detector for giving the goal of detection but i couldn't found out how should i use this service!
is there any tutorial for using tabletop_objects_detector?
Thanks.
Originally posted by minoo on ROS Answers with karma: 11 on 2012-02-04
Hi, There is no tutorial for the same. But if you want to do the detection of the tabletop_objects you may look at the tutorials at http://pointclouds.org/documentation/tutorials/ and read through the below topics
a. Euclidean cluster extraction.
b. Cluster recognition and 6D pose estimation.
I used them straight forwardly for my work of detecting the tabletop_objects.
Hope this helps!
Thanks, Karthik
Originally posted by karthik with karma: 2831 on 2012-02-07
