Hi all, I've checked out rosjava from mercurial in my ros package path. It complains with the import statement of DefaultNodeFactory:
compile:
[javac] /home/u0062536/ros/raw/kb-home-pkg/HA_android_GUI/build.xml:26: warning: 'includeantruntime' was not set, defaulting to build.sysclasspath=last; set to false for repeatable builds
[javac] Compiling 2 source files to /home/u0062536/ros/raw/kb-home-pkg/HA_android_GUI/build
[javac] /home/u0062536/ros/raw/kb-home-pkg/HA_android_GUI/src/rostest.java:6: cannot find symbol
[javac] symbol : class DefaultNodeFactory
[javac] location: package org.ros.node
[javac] import org.ros.node.DefaultNodeFactory;
[javac] ^
[javac] 1 error
BUILD FAILED
This on a easy java code example:
import java.net.URI;
import java.net.URISyntaxException;
import org.ros.address.InetAddressFactory;
import org.ros.node.Node;
import org.ros.node.NodeConfiguration;
* The HelloWorldApp class implements an application that
* simply prints "Hello World!" to standard output.
class RosTestApp {
public static void main(String[] args) {
System.out.println("Hello World, trying to get ROS to work, with NF!"); // Display the string.
If the DefaultNodeFactory is commented out the code does work perfect. Rosjava compiles fine and is added in the manifest of this package. The goal of the package is to build a android app that uses rosjava to connect to a roscore.
Originally posted by KoenBuys on ROS Answers with karma: 2314 on 2012-01-16
