I am new to ROS and I followed the directions for creating/making/running ros packages, but I get an immediate seg fault.
Here is what i did:
- cd ~/ros_workspace
- roscreate-pkg begtut std_msgs rospy roscpp
- rosmake begtut
- created talker.cpp from the tutorials and saved to src
- added rosbuild_add_executable(talker src/talker.cpp) to CMakelists.txt
- make
- run roscore
- rosrun begtut talker
I get "Segmentation fault" written to the screen
What am I missing?
Originally posted by bobby on ROS Answers with karma: 26 on 2012-01-06
Comment by bobby on 2012-01-06:
Yes, it build no problem.
Comment by DimitriProsser on 2012-01-06:
Did you verify that the code was copied completely correctly?
