The pelican.xml file is not configured properly to launch in Gazebo. I've managed a quick fix that you can use. You must add and tags to the xml file so that Gazebo can provide the correct physics to the model. I've also added tags to specify physics parameters and colors. I've included an example from my modified file. You can further modify it to improve upon it later, particularly the model dynamics and physics. I hope that this helps.
URDF: Pelican URDF Example
Originally posted by DimitriProsser with karma: 11163 on 2011-09-14
Post score: 5
Comment by DimitriProsser on 2011-12-27:
The best way is if you start a new question with your problem. That way, everyone can benefit from the help.
Comment by hmmm on 2011-12-26:
Hi,i used your pelican urdf ,but it does not show me the whole quadrotor. What am i doing wrong??@ DimitriProsser : Is there a oppertunity that i can send you my urdf as email?So that you can have a look ? thanks,regards
Comment by Steven Bellens on 2011-09-15:
Thanks, that gets me started!
