Is it possible to use the household objects database with a custom objects set? What I mean is to use the same objects already in the database but instead of loading all of them to be able to specify which subset I want (by giving a list of model ids). Right now the only options that I know of are "REDUCED_MODEL_SET" and "" which gives me all the objects in the database
Here is an example of a part of a launch file where this is set.
  <include file="$(find tabletop_object_detector)/launch/tabletop_node.launch"/>
  <param name="/tabletop_node/use_database" value="true"/>
  <param name="/tabletop_node/model_set" value="REDUCED_MODEL_SET" />
  <param name="/tabletop_node/get_model_list_srv" value="/objects_database_node/get_model_list" />
  <param name="/tabletop_node/get_model_mesh_srv" value="/objects_database_node/get_model_mesh" />
  <node pkg="tabletop_collision_map_processing" name="tabletop_collision_map_processing"
        type="tabletop_collision_map_processing_node" respawn="false" output="screen"/>
  <param name="tabletop_collision_map_processing/get_model_mesh_srv"
Originally posted by Dimitar Simeonov on ROS Answers with karma: 535 on 2011-06-02
There's also the DEBUG_MODEL_SET with only a few models.
You're best bet (if you have write access to the database), would be to add your own model set. You just need to add the models number you want to the model_set table, associated with a model set name.
Hope this helps.
Originally posted by Ugo with karma: 1620 on 2011-06-02
Comment by Ugo on 2011-06-06:
Ok, no worries. But you do know that setting up a local version of the database won't take you very long and is very straightforward?
Comment by Dimitar Simeonov on 2011-06-06:
I guess the right thing would be do get a local version of the database and to modify the entry - however I decided to stick with the full database for now. Thanks
Comment by Dimitar Simeonov on 2011-06-02:
Thank you Ugo, but I am using the remote version of the database. I prefer not to have a local version of the database, unless I really really need to.
