Hi,
after launching the remote client to the household objects database with
$ roslaunch household_objects_database objects_database_remote_client.launch
(which correctly remaps the services), queries to the database always return a result code 3 DATABASE_QUERY_ERROR, e.g. for the following queries on both cturtle and diamondback.
$ rosservice call /objects_database_node/get_model_list REDUCED_MODEL_SET
$ rosservice call /objects_database_node/get_model_mesh 18800
Has the service definition changed, or is the server down?
best, Moritz
Originally posted by moritz on ROS Answers with karma: 2673 on 2011-02-28
Hello Moritz,
Did you follow these tutorials?
http://www.ros.org/wiki/sql_database/Tutorials/Installing%20a%20PostgreSQL%20Server
and
http://www.ros.org/wiki/household_objects_database/Tutorials/Install%20the%20household_objects%20database%20on%20your%20local%20database%20server
You should make sure that you can log in your database and that it is not empty using pgadmin3 on the computer where the database is installed.
Please, make sure that your my_server.yaml file contains the correct login information and that your launch file (objects_database_remote_client.launch) uses it.
You can make sure of the service definition by using rosservice:
$rosservice list
$rosservice type [SERVICE_NAME]
$rosservice info [SERVICE_NAME]
If it does not help, please send your launch file, yaml file, and a screenshot of your rxgraph.
Raph
Originally posted by raphael favier with karma: 1382 on 2011-03-01
Hi,
the problem occurred when using the database hosted at Willow Garage, and got solved by Matei who re-started their server :)
Thanks anyway, Moritz
Originally posted by moritz with karma: 2673 on 2011-03-02
Comment by raphael favier on 2011-03-02:
ok :) glad to hear you solved your problem
