Hello, I am running GMapping and visualizing the map in Rviz. My fixed frame is set to /map. I am driving the robot around manually and am generating a fairly accurate map. My problem is that the link from odom to base_link seems to be moving in the opposite direction. Base_link remains fixed where at the origin like I expect, but odom moves the opposite direction of the robot. My /odom ends up being no where near where the map is being generated, but the map still looks fine. My /odom is publishing that it is at X=3.28, Y=0.44, theta=-11.128 degrees. However, when I look at its position in RViz for the odom frame, I get X=-0.61441, Y=-0.22086.
Originally posted by tyleroar on ROS Answers with karma: 1 on 2011-04-20
REP 105 does a good job of explaining how the various mapping frames interact.
In short, what you're seeing there is what's expected; /odom is the uncorrected odometric information, and will not only be wrong, but will be arbitrarily wrong, given enough time.
Originally posted by Mac with karma: 4119 on 2011-04-21
Comment by sam on 2012-02-19:
Is /odom should move away from /map when gmapping building a map and robot moving? Thank you~
