Hello List
I'm a newbie to Gazebo and have been experimenting with it for the last couple of days. So now I have a small problem, I wrote a simple 4 wheels robot (attached to this email) which spawns perfectly in gazebo. Now whenever I apply a body wrench, I get the following warning in Gazebo "[ WARN] [1299848525.581625793, 11872.099000000]: ApplyBodyWrench: reference frame and reference_point not implemented yet, force is defined and applied at the body frame"
rosservice call gazebo/apply_body_wrench '{body_name: "car::left_front_wheel" , wrench: { force: { x: 0.1, y: 0, z: 0 } , torque: { x: 0.0, y: 0 , z: 0 } }, start_time: 10000000000, duration: 1000000000 }'
The car moves actually the way I want, but it I'd understande from that warning that the force is applied to the base_link and not to the wheel the way I want. Or did I miss something?
Thanks alot for the help Best regards Moataz
wheels_robot4.urdf
<?xml version="1.0" ?>
<!-- | This document was autogenerated by xacro from wheels_robot4.xacro | -->
<!-- | EDITING THIS FILE BY HAND IS NOT RECOMMENDED | -->
<robot name="wheels_robot" xmlns:body="http://playerstage.sourceforge.net/gazebo/xmlschema/#body" xmlns:geom="http://playerstage.sourceforge.net/gazebo/xmlschema/#geom" xmlns:joint="http://playerstage.sourceforge.net/gazebo/xmlschema/#joint" xmlns:model="http://playerstage.sourceforge.net/gazebo/xmlschema/#model" xmlns:sensor="http://playerstage.sourceforge.net/gazebo/xmlschema/#sensor" xmlns:visual="http://playerstage.sourceforge.net/gazebo/xmlschema/#visual" xmlns:xacro="http://playerstage.sourceforge.net/gazebo/xmlschema/#interface">
<link name="base_link">
<inertial>
<mass value="1"/>
<inertia ixx="1.0" ixy="0.0" ixz="0.0" iyy="1.0" iyz="0.0" izz="1.0"/>
</inertial>
<visual>
<geometry>
<box size="1 0.6 0.1"/>
</geometry>
</visual>
<collision>
<geometry>
</geometry>
</collision>
</link>
<link name="left_front_wheel">
<visual>
<origin rpy="0 0 0" xyz="0 0 0"/>
<geometry>
<cylinder length="0.11" radius="0.096"/>
</geometry>
<material name="Cyan1">
<color rgba="0 1 1 1.0"/>
</material>
</visual>
<collision>
<geometry>
</geometry>
</collision>
<inertial>
<mass value="0.1"/>
</inertial>
</link>
<link name="right_front_wheel">
<visual>
<geometry>
</geometry>
</material>
</visual>
<collision>
<geometry>
</geometry>
</collision>
<inertial>
<mass value="0.1"/>
</inertial>
</link>
<link name="left_back_wheel">
<visual>
<geometry>
</geometry>
</material>
</visual>
<collision>
<geometry>
</geometry>
</collision>
<inertial>
<mass value="0.1"/>
</inertial>
</link>
<link name="right_back_wheel">
<visual>
<geometry>
</geometry>
</material>
</visual>
<collision>
<geometry>
</geometry>
</collision>
<inertial>
<mass value="0.1"/>
</inertial>
</link>
<joint name="left_front_wheel_hinge" type="continuous">
<parent link="base_link"/>
<child link="left_front_wheel"/>
<axis xyz="0 0 1"/>
<origin rpy="80.02 0 0" xyz="0.41 0.3 -0.06"/>
</joint>
<joint name="right_front_wheel_hinge" type="continuous">
<child link="right_front_wheel"/>
<axis xyz="0 0 1"/>
<origin rpy="80.02 0 0" xyz="0.41 -0.3 -0.06"/>
</joint>
<joint name="left_back_wheel_hinge" type="continuous">
<child link="left_back_wheel"/>
<axis xyz="0 0 1"/>
<origin rpy="80.02 0 0" xyz="-0.41 0.3 -0.06"/>
</joint>
<joint name="right_back_wheel_hinge" type="continuous">
<child link="right_back_wheel"/>
<axis xyz="0 0 1"/>
<origin rpy="80.02 0 0" xyz="-0.41 -0.3 -0.06"/>
</joint>
<gazebo reference="base_link">
<mu1>10</mu1>
<mu2>10</mu2>
<turnGravityOff>true</turnGravityOff>
<material>Gazebo/Green</material>
</gazebo>
<gazebo reference="left_front_wheel">
<mu1>10</mu1>
<mu2>10</mu2>
<material>Gazebo/WoodFloor</material>
</gazebo>
<gazebo reference="right_front_wheel">
<mu1>10</mu1>
<mu2>10</mu2>
<material>Gazebo/Blue</material>
</gazebo>
<gazebo reference="left_back_wheel">
<mu1>10</mu1>
<mu2>10</mu2>
</gazebo>
<gazebo reference="right_back_wheel">
<mu1>10</mu1>
<mu2>10</mu2>
</gazebo>
</robot>
Originally posted by Moataz Elmasry on ROS Answers with karma: 126 on 2011-03-16
