Hi, I find the following error message when trying to compile my code, by using the "make" command. All the required libraries (.so and .a) are in the /lib folder of my project source directory. What am I doing wrong?
Error message:
Linking CXX executable bin/basic_soar_test
/usr/bin/ld: cannot find -lElementXML
collect2: ld returned 1 exit status
make[2]: *** [bin/basic_soar_test] Error 1
make[1]: *** [CMakeFiles/basic_soar_test.dir/all] Error 2
make: *** [all] Error 2
The contents of my CMakeLists file are:
cmake_minimum_required(VERSION 2.4.6)
include($ENV{ROS_ROOT}/core/rosbuil
rosbuild_init()
set(EXECUTABLE_OUTPUT_PATH ${PROJECT_SOURCE_DIR}/bin)
set(LIBRARY_OUTPUT_PATH ${PROJECT_SOURCE_DIR}/lib)
rosbuild_add_executable(basic_soar_test example/basic_soar_test.cpp)
target_link_libraries(basic_soar_test ElementXML ConnectionSML SoarKernelSML ClientSML)
Thanks in advance!
Originally posted by tomurillo on ROS Answers with karma: 55 on 2011-03-08
