Gazebo Answers logo
I run a simulation into which I spawn a robot with gazebo_ros_control plugin called simply "gazebo_ros_control". This loads all successfully. Then there is a model inside the world which has gazebo_ros_control plugin. This one only starts the joint_states topic, but not the command, pid and state topic for each joint individually.
plugin of the model inside the world:
  <transmission name="tran_robotic_arm">
    <type>transmission_interface/SimpleTransmission</type>
    <joint name="arm_base_joint1">
      <hardwareInterface>hardware_interface/VelocityJointInterface</hardwareInterface>
    </joint>
    <actuator name="arm_base_motor">
      <mechanicalReduction>1</mechanicalReduction>
    </actuator>
  </transmission>
  <plugin name="testbench_control" filename="libgazebo_ros_control.so">
    <robotNamespace>/testbench</robotNamespace>
    <robotSimType>gazebo_ros_control/DefaultRobotHWSim</robotSimType>
    <legacyModeNS>true</legacyModeNS>
  </plugin>
control yaml
testbench:
  joint_state_controller:
    type: joint_state_controller/JointStateController
    publish_rate: 50
  arm_base_joint1_controller:
    type: velocity_controllers/JointVelocityController
    joint: arm_base_joint1
    pid: {p: 10.0, i: 0.1, d: 0.01}
control launch file:
<launch>
  <!-- Load joint controller configurations from YAML file to parameter server -->
  <rosparam file="$(find testbench_control)/config/control.yaml" command="load"/>
  <!-- load the controllers -->
  <node name="controller_spawner" pkg="controller_manager" type="spawner" respawn="false"
    output="screen" ns="/testbench" args=" joint_state_controller
                                      arm_base_joint1_controller" />
  <!-- convert joint states to TF transforms for rviz, etc -->
  <node name="robot_state_publisher" pkg="robot_state_publisher" type="robot_state_publisher"
    respawn="false" output="screen">
    <remap from="/joint_states" to="/testbench/joint_states" />
  </node>
</launch>
launch file
<?xml version="1.0"?>
<launch>
    <!-- testbench ros_control launch file -->
    <!-- creates topics for joints state and joint controller -->
    <include file="$(find testbench_control)/launch/control.launch" />
</launch>
I launch this launch file after the simulation is all loaded. I want to use the /testbench/arm_base_joint1_controller/command topic to control the robotic arm joint. Is it possible? What am I doing wrong?
Originally posted by kumpakri on Gazebo Answers with karma: 755 on 2019-01-30
Gazebo Answers logo
Turned out, that if I use this --namespace argument when launching the controller_spawner, the gazebo_ros_control plugin is launched in that namespace and you can launch several of them this way.
    output="screen" ns="/robot1" args=" --namespace=/robot1
                                      joint_left_wheel_controller
                                      joint_right_wheel_controller" />
Originally posted by kumpakri with karma: 755 on 2019-02-05
Comment by Oscar Lima on 2021-03-01:
no need to add "--namespace=/robot1" , otherwise provided answer is correct
