I see that effort_controllers/JointPositionController looks for the particular joint and assigns the corresponding PID value to the control_toolbox::Pid variable. effort_controllers/JointGroupPositionController also does the same thing for all the joints inside the controller in a for loop. So essentially there is no difference between the two except for in the .yaml file and the launch files.
When I try to load a effort_controllers/JointGroupPositionController with the following .yaml file and launch file, I am getting the following error: "Failed to getParam 'joints' (namespace: /my_6dof_robot/joint_group_position_controller)".
[INFO] [1572904736.013589, 0.511000]: Controller Spawner: Waiting for service controller_manager/switch_controller
[INFO] [1572904736.015633, 0.512000]: Controller Spawner: Waiting for service controller_manager/unload_controller
[INFO] [1572904736.017165, 0.513000]: Loading controller: joint_group_position_controller
[ERROR] [1572904736.025517675, 0.519000000]: Failed to getParam 'joints' (namespace: /my_6dof_robot/joint_group_position_controller).
[ERROR] [1572904736.025622082, 0.519000000]: Failed to initialize the controller
[ERROR] [1572904736.025671797, 0.519000000]: Initializing controller 'joint_group_position_controller' failed
[ERROR] [1572904737.027262, 1.296000]: Failed to load joint_group_position_controller
[INFO] [1572904737.027650, 1.296000]: Loading controller: joint_state_controller
[INFO] [1572904737.035878, 1.303000]: Controller Spawner: Loaded controllers: joint_state_controller
[INFO] [1572904737.045714, 1.309000]: Started controllers: joint_state_controller
It succeeds in loading the joint_state_controller.
The .yaml file (my_6dof_robot_effort_control.yaml) is as follows:
my_6dof_robot:
joint_state_controller:
type: joint_state_controller/JointStateController
publish_rate: 50
joint_group_position_controller:
type: effort_controllers/JointGroupPositionController
joints:
joint_base_link1:
pid: {p: 600.0, i: 80.0, d: 200.0}
joint_link1_link2:
pid: {p: 11000.0, i: 100.0, d: 500.0}
joint_link2_link3:
pid: {p: 8000.0, i: 300.0, d: 400.0}
joint_link3_link4:
pid: {p: 400.0, i: 40.0, d: 60.0}
joint_link4_link5:
pid: {p: 400.0, i: 10.0, d: 10.0}
joint_link5_link6:
pid: {p: 20.0, i: 0.8, d: 0.1}
The gazebo and control launch file is as follows:
<launch>
<arg name="paused" default="false"/>
<arg name="use_sim_time" default="true"/>
<arg name="gui" default="true"/>
<arg name="headless" default="false"/>
<arg name="debug" default="false"/>
<include
file="$(find gazebo_ros)/launch/empty_world.launch">
<arg name="debug" value="$(arg debug)" />
<arg name="gui" value="$(arg gui)" />
<arg name="paused" value="$(arg paused)"/>
<arg name="use_sim_time" value="$(arg use_sim_time)"/>
<arg name="headless" value="$(arg headless)"/>
</include>
<param name="robot_description" command="$(find xacro)/xacro --inorder $(find my_6dof_robot_description)/urdf/my_6dof_robot_robot.xacro"/>
<node name="spawn_my_6dof_robot" pkg="gazebo_ros" type="spawn_model"
args="-param robot_description
-urdf
-x 0
-y 0
-z 0
-model my_6dof_robot"
respawn="false" output="screen">
</node>
<rosparam file="$(find my_6dof_robot_control)/config/my_6dof_robot_effort_control.yaml" command="load" />
<node name="controller_spawner" pkg="controller_manager" type="spawner" respawn="false" ns="/my_6dof_robot_robot"
output="screen" args="joint_group_position_controller joint_state_controller --timeout 50">
</node>
<node name = "robot_state_publisher" pkg = "robot_state_publisher" type = "robot_state_publisher" respawn="false" output="screen">
<remap from="/joint_states" to="/my_6dof_robot_robot/joint_states" />
</node>
</launch>
However, when I load the effort_controllers/JointPositionController with the following .yaml and launch file, it is a success.
my_6dof__robot:
publish_rate: 50
joint1_position_controller:
type: effort_controllers/JointPositionController
joint: joint_base_link1
joint2_position_controller:
joint: joint_link1_link2
joint3_position_controller:
joint: joint_link2_link3
joint4_position_controller:
joint: joint_link3_link4
joint5_position_controller:
joint: joint_link4_link5
joint6_position_controller:
joint: joint_link5_link6
.launch file:
<launch>
<include
</include>
-urdf
-x 0
-y 0
-z 0
</node>
output="screen" args="joint1_position_controller joint2_position_controller joint3_position_controller joint4_position_controller joint5_position_controller joint6_position_controller joint_state_controller joint_state_controller --timeout 50">
</node>
</node>
</launch>
The my_6dof_robot.urdf is has the following gazebo_ros_plugin tag in both the cases:
<gazebo>
<plugin name="gazebo_ros_control" filename="libgazebo_ros_control.so">
<robotSimType>gazebo_ros_control/DefaultRobotHWSim</robotSimType>
<robotNamespace>/my_6dof_robot</robotNamespace>
<robotParam>robot_description</robotParam>
<legacyModeNS>true</legacyModeNS>
</plugin>
</gazebo>
I think the error has something to do with the namespace. I want to know what Iam doing wrong. The same error is appearing when I try to load my custom controller instead of the joint_group_position_controller. Any help is highly appreciated.
Thank you!!
Originally posted by sthakar on ROS Answers with karma: 1 on 2019-10-29
Comment by gvdhoorn on 2019-10-29:
Please show a verbatim copy of the actual (and complete) error message.
Comment by sthakar on 2019-10-30:
Thanks! I have edited the question. Please let me know if you need any more information. Thank you!
