Hi, I am trying to launch my world file with my custom robot spawned at launch, I follow the urdf tutorial at Gazebo main page, but the model won't spawn.
<launch>
<!-- We resume the logic in empty_world.launch, changing only the name of the world to be launched -->
<include file="$(find gazebo_ros)/launch/empty_world.launch">
<arg name="world_name" value="$(find kuka_kr3_gazebo)/worlds/kuka_kr3.world"/>
<!-- more default parameters can be changed here -->
</include>
<!-- Spawn a robot into Gazebo -->
<param name="robot_description" textfile="$(find kuka_kr3_description)/urdf/model.urdf"/>
<node name="spawn_urdf" pkg="gazebo_ros" type="spawn_model" args="-file $(find kuka_kr3_description)/urdf/model.urdf -urdf -param robot_description -x 0.0 -y 0.0 -z 0.1 -model kuka_kr3" respawn="false" output="screen"/>
</launch>
The launch file runs 'correctly' but there is no robot model, I think this piece of log from console might be connected:
process[rosout-1]: started with pid [7932]
started core service [/rosout]
process[gazebo-2]: started with pid [7940]
process[gazebo_gui-3]: started with pid [7950]
process[spawn_urdf-4]: started with pid [7958]
SpawnModel script started
No handlers could be found for logger "rosout"
[ INFO] [1507552317.153725427]: Finished loading Gazebo ROS API Plugin.
[ INFO] [1507552317.154071045]: waitForService: Service [/gazebo/set_physics_properties] has not been advertised, waiting...
[spawn_urdf-4] process has finished cleanly
I can spawn the robot model using rosrun command
rosrun gazebo_ros spawn_model -file `rospack find kuka_kr3_description`/urdf/model.urdf -urdf -x 0 -y 0 -z 1 -model kuka_kr3
but this isn't exactly what I want.
I am also wondering if that may cause problems that I have with a controller - the values of PID from controller aren't the same as the ones in Gazebo, and I think that causes problems when I try to control it from Moveit.
EDIT that part with the controller has not been connected with that, but the spawning problem still remains.
Originally posted by Fiddle on Gazebo Answers with karma: 35 on 2017-10-09
