I import two links from solidworks, they are stl files, and I add coodinate system on a hole of the two links,now I want to make the second lind rotate around the setted X axis, but it can not ,how can I deal with it? the code as follow: link: 0 1.0 0.0 0 0 0 .......link1.stl
world link 1 0 0Originally posted by lugd1229 on Gazebo Answers with karma: 75 on 2012-12-03
Comment by asomerville on 2012-12-03:
Can you clarify? I cant quite tell what you're asking.
Comment by lugd1229 on 2012-12-03:
I will use plugin animate a link rotate around a setting axis of a coordinate system attached on another link.
