So I have build a 6-axis manipulator having all the degree of freedom. Currently I have used TeensyStep library for controlling synchronization of 6 stepper axis. Also I have tried AccelStepper library for controlling 6-axis stepper synchronization. Until now everything works great.
But now I have to move the robot (all 6-axis), with the help of numeric control code. (Basically what happens in 3D printer control with Gcode)
For example :
N001 A1 150, A2 32.6, A3 -50, A4 -75.8, A5 50, A6 10.2
N002 A1 120, A2 42.6, A3 -55.0, A4 88, A5 150, A6 10.8
N003 A1 50, A2 3.6, A3 -5.50, A4 -5.8, A5 150, A6 1.2
N004 A1 158, A2 38, A3 80, A4 7.8, A5 44.4, A6 100.2
where A1 to A6 represents angle values in degree.
With AccelStepper or TeensyStep library I can move to give code line(N00x) in a synchronous move. So when I feed this code lines it will go from current position accelerating-to maxSpeed- then deaccelerating to target position.
What I want to do is to move from one code line to next code line and to next in One-Continuous move. That is no accelerating from start position to setSpeed/maxSpeed to first point - then to next point - then to next point and deaccelerating finally at the end of code line. So if there is new code line in the buffer it will not deaccelerate, go to current target with maxSpeed/setSpeed and then to new target with updated speed and so on.
Basically what Computer Numeric Control(CNC) machines do.
I tried searching regarding this in many different platforms but can't find anything closely related to this.
Thank you.
