Recently i have fused odom and imu data using ekf the filterd odom data is very good .For Vx and theta velocity the localisation is good but when i put both of the velocities 0.5 the robot misses its localisation and becomes stray. I have fused IMU and Odometry Please find the video of the problem video. Below are the AMCL parameters.
amcl:
ros__parameters:
use_sim_time: False
alpha1: 1.0
alpha2: 0.8
alpha3: 0.5
alpha4: 0.3
alpha5: 0.2
base_frame_id: "base_footprint"
beam_skip_distance: 0.5
beam_skip_error_threshold: 0.9
beam_skip_threshold: 0.3
do_beamskip: false
global_frame_id: "map"
lambda_short: 0.1
laser_likelihood_max_dist: 2.0
laser_max_range: -1.0
laser_min_range: -1.0
laser_model_type: "likelihood_field"
max_beams: 60
max_particles: 2000
min_particles: 500
odom_frame_id: "odom"
pf_err: 0.05
pf_z: 0.99
recovery_alpha_fast: 0.0
recovery_alpha_slow: 0.0
resample_interval: 1
robot_model_type: "nav2_amcl::DifferentialMotionModel"
save_pose_rate: 0.5
initial_pose: [0.0, 0.0, 0.0]
set_initial_pose: True
sigma_hit: 0.2
tf_broadcast: true
transform_tolerance: 0.2
update_min_a: 0.01
update_min_d: 0.01
z_hit: 0.5
z_max: 0.05
z_rand: 0.5
z_short: 0.05
scan_topic: lidar_front_right/scan
amcl_map_client:
ros__parameters:
use_sim_time: False
amcl_rclcpp_node:
ros__parameters:
use_sim_time: False
bt_navigator:
ros__parameters:
use_sim_time: False
global_frame: map
robot_base_frame: base_link
odom_topic: /filtered_odometry
default_bt_xml_filename: "navigate_w_replanning_and_recovery.xml" ####remove and check
bt_loop_duration: 10
default_server_timeout: 20
enable_groot_monitoring: True
groot_zmq_publisher_port: 1666
groot_zmq_server_port: 1667
plugin_lib_names:
- nav2_compute_path_to_pose_action_bt_node
- nav2_compute_path_through_poses_action_bt_node
- nav2_follow_path_action_bt_node
- nav2_back_up_action_bt_node
- nav2_spin_action_bt_node
- nav2_wait_action_bt_node
- nav2_clear_costmap_service_bt_node
- nav2_is_stuck_condition_bt_node
- nav2_goal_reached_condition_bt_node
- nav2_goal_updated_condition_bt_node
- nav2_initial_pose_received_condition_bt_node
- nav2_reinitialize_global_localization_service_bt_node
- nav2_rate_controller_bt_node
- nav2_distance_controller_bt_node
- nav2_speed_controller_bt_node
- nav2_truncate_path_action_bt_node
- nav2_goal_updater_node_bt_node
- nav2_recovery_node_bt_node
- nav2_pipeline_sequence_bt_node
- nav2_round_robin_node_bt_node
- nav2_transform_available_condition_bt_node
- nav2_time_expired_condition_bt_node
- nav2_distance_traveled_condition_bt_node
- nav2_single_trigger_bt_node
- nav2_is_battery_low_condition_bt_node
- nav2_navigate_through_poses_action_bt_node
- nav2_navigate_to_pose_action_bt_node
- nav2_remove_passed_goals_action_bt_node
- nav2_planner_selector_bt_node
- nav2_controller_selector_bt_node
- nav2_goal_checker_selector_bt_node
bt_navigator_rclcpp_node:
ros__parameters:
use_sim_time: False
controller_server:
ros__parameters:
use_sim_time: true
controller_frequency: 10.0
min_x_velocity_threshold: 0.001
min_y_velocity_threshold: 0.5
min_theta_velocity_threshold: 0.001
failure_tolerance: 10.0
progress_checker_plugin: "progress_checker"
goal_checker_plugins: ["general_goal_checker"]
controller_plugins: ["FollowPath"]
progress_checker:
plugin: "nav2_controller::SimpleProgressChecker"
required_movement_radius: 0.5
movement_time_allowance: 10.0
general_goal_checker:
stateful: True
plugin: "nav2_controller::SimpleGoalChecker"
xy_goal_tolerance: 0.3
yaw_goal_tolerance: 0.17
FollowPath:
plugin: "dwb_core::DWBLocalPlanner"
debug_trajectory_details: True
min_vel_x: -0.0
min_vel_y: 0.0
max_vel_x: 0.8 #For adjusting speed
max_vel_y: 0.0
max_vel_theta: 0.8 #For adjusting angle
min_speed_xy: 0.0
max_speed_xy: 0.62
min_speed_theta: 0.05
acc_lim_x: 2.5
acc_lim_y: 0.0
acc_lim_theta: 4.0
decel_lim_x: -2.5
decel_lim_y: 0.0
decel_lim_theta: -3.8 #-3.2
vx_samples: 200
vy_samples: 0
vtheta_samples: 40
sim_time: 1.5
linear_granularity: 0.05
angular_granularity: 0.025
transform_tolerance: 0.3
trans_stopped_velocity: 0.25
short_circuit_trajectory_evaluation: True
stateful: True
critics: ["RotateToGoal", "Oscillation", "BaseObstacle", "GoalAlign", "PathAlign", "PathDist", "GoalDist"]
BaseObstacle.scale: 0.02
PathAlign.scale: 32.0
PathAlign.forward_point_distance: 0.325
GoalAlign.scale: 24.0
GoalAlign.forward_point_distance: 0.325
PathDist.scale: 32.0
GoalDist.scale: 20.0
RotateToGoal.scale: 32.0
RotateToGoal.slowing_factor: 5.0
RotateToGoal.lookahead_time: -1.0
controller_server_rclcpp_node:
ros__parameters:
use_sim_time: False
local_costmap:
local_costmap:
ros__parameters:
update_frequency: 10.0
publish_frequency: 5.0
global_frame: map
robot_base_frame: base_footprint
use_sim_time: False
rolling_window: true
width: 5
height: 5
resolution: 0.1
robot_radius: 0.42
plugins: ["obstacle_layer", "voxel_layer", "inflation_layer"]
filters: ["keepout_filter", "inflation_layer"]
keepout_filter:
plugin: "nav2_costmap_2d::KeepoutFilter"
enabled: True
filter_info_topic: "/costmap_filter_info"
inflation_layer:
plugin: "nav2_costmap_2d::InflationLayer"
cost_scaling_factor: 15.0
inflation_radius: 0.2
obstacle_layer:
plugin: "nav2_costmap_2d::ObstacleLayer"
enabled: True
inflation_radius: 0.1 #0.2---1
observation_sources: lidar_front_right/scan lidar_rear_left/scan
lidar_front_right/scan:
topic: /lidar_front_right/scan
max_obstacle_height: 2.0
clearing: True
marking: True
data_type: "LaserScan"
lidar_rear_left/scan:
topic: /lidar_rear_left/scan
clearing: True
marking: True
voxel_layer:
plugin: "nav2_costmap_2d::VoxelLayer"
enabled: True
publish_voxel_map: True
origin_z: 0.0
z_resolution: 0.05
z_voxels: 16
mark_threshold: 0
clearing: True
marking: True
raytrace_max_range: 5.0
raytrace_min_range: 0.0
obstacle_max_range: 5.0
obstacle_min_range: 0.0
clearing: True
marking: True
raytrace_max_range: 6.0
static_layer:
map_subscribe_transient_local: True
always_send_full_costmap: True
global_costmap:
global_costmap:
ros__parameters:
global_frame: map
use_sim_time: false
robot_radius: 0.42
resolution: 0.05
track_unknown_space: true
plugins: ["static_layer", "obstacle_layer", "voxel_layer", "inflation_layer"]
keepout_filter:
enabled: True
obstacle_layer:
enabled: True
inflation_radius: 0.6
clearing: True
marking: True
clearing: True
marking: True
voxel_layer: # Move this section outside of ros__parameters
enabled: True
origin_z: 0.0
z_resolution: 0.05
z_voxels: 16
mark_threshold: 0
clearing: True
marking: True
clearing: True
marking: True
static_layer:
plugin: "nav2_costmap_2d::StaticLayer"
inflation_layer:
cost_scaling_factor: 25.0
global_costmap_client:
ros__parameters:
use_sim_time: False
global_costmap_rclcpp_node:
ros__parameters:
use_sim_time: False
map_server:
ros__parameters:
use_sim_time: False
yaml_filename: "map_17_10_24.yaml"
map_saver:
ros__parameters:
use_sim_time: False
save_map_timeout: 5000 #foxy 5000
free_thresh_default: 0.25
occupied_thresh_default: 0.65
planner_server:
ros__parameters:
expected_planner_frequency: 1.0
use_sim_time: False
planner_plugins: ["GridBased"]
GridBased:
plugin: "nav2_navfn_planner/NavfnPlanner"
tolerance: 1.0 #foxy 1.0
use_astar: true #foxy true
allow_unknown: true
planner_server_rclcpp_node:
ros__parameters:
use_sim_time: False
recoveries_server:
ros__parameters:
costmap_topic: local_costmap/costmap_raw
footprint_topic: local_costmap/published_footprint
cycle_frequency: 1.0
recovery_plugins: ["spin", "backup", "wait"]
spin:
plugin: "nav2_recoveries/Spin"
backup:
plugin: "nav2_recoveries/BackUp"
wait:
plugin: "nav2_recoveries/Wait"
global_frame: odom
transform_timeout: 0.1
use_sim_time: false
simulate_ahead_time: 2.0
max_rotational_vel: 0.3 #foxy 3.0
min_rotational_vel: 0.05
rotational_acc_lim: 1.2 #foxy 1.2
robot_state_publisher:
ros__parameters:
use_sim_time: False
waypoint_follower:
ros__parameters:
loop_rate: 2000 ####20
stop_on_failure: false
waypoint_task_executor_plugin: "wait_at_waypoint"
wait_at_waypoint:
plugin: "nav2_waypoint_follower::WaitAtWaypoint"
enabled: True
waypoint_pause_duration: 200
smoother_server:
ros__parameters:
# General parameters
update_rate: 20.0
# Trajectory smoothing parameters
smoother_type: "velocity_smoother"
velocity_smoother:
type: "nav2_smoother::VelocitySmoother"
lookahead_time: 0.5
samples: 10
min_samples: 5
max_samples: 20
alpha: 0.8
beta: 0.2
max_velocity_xy: 0.5
max_velocity_theta: 0.5
smoothing_frequency: 80.0
# Other parameters
motion_model_for_search: "DifferentialDrive"
pose_distance: 0.25
publish_predicted_path: false
publish_filtered_path: false
realsense_node:
ros__parameters:
topics:
color:
image: "/camera/color/image_raw"
camera_info: "/camera/color/camera_info"
depth:
image: "/camera/depth/image_rect_raw"
infra1:
image: "/camera/infra1/image_rect_raw"
infra2:
image: "/camera/infra2/image_rect_raw"
depth_scale_meters: 0.001
behavior_server:
ros__parameters:
bond_disable_heartbeat_timeout: true
backup.plugin: nav2_behaviors/BackUp
behavior_plugins:
- spin
- backup
- drive_on_heading
- wait
cycle_frequency: 20.0
drive_on_heading.plugin: nav2_behaviors/DriveOnHeading
global_frame: odom
max_rotational_vel: 0.1
rotational_acc_lim: 2.0
spin.plugin: nav2_behaviors/Spin
transform_tolerance: 0.5
use_sim_time: false
wait.plugin: nav2_behaviors/Wait
velocity_smoother:
ros__parameters:
feedback: OPEN_LOOP
odom_duration: 0.1
scale_velocities: true
smoothing_frequency: 150.0
use_sim_time: False
velocity_timeout: 1.0
**EKF node**
ekf_filter_node:
ros__parameters:
use_sim_time: false
frequency: 30.0
sensor_timeout: 0.1
two_d_mode: true
transform_time_offset: 0.0
transform_timeout: 0.0
print_diagnostics: true
debug: false
debug_out_file: /path/to/debug/file.txt
publish_tf: false
publish_acceleration: false
reset_on_time_jump: false
map_frame: map
odom_frame: /odom
base_link_frame: /base_footprint
world_frame: /odom
odom0: /odom
odom0_config: [true, true, true,
false, false, true,
true, true, true,
false, false, false,
false, false, false]
odom0_queue_size: 2
odom0_nodelay: false
odom0_differential: false
odom0_relative: true
odom0_pose_rejection_threshold: 5.0
odom0_twist_rejection_threshold: 1.0
imu0: /imu_data
imu0_config: [false, false, false,
true, true, false,
true, true, true,
true, true, true,
true, true, true]
imu0_nodelay: false
imu0_differential: false
imu0_relative: true
imu0_queue_size: 7
imu0_pose_rejection_threshold: 0.8
imu0_twist_rejection_threshold: 0.8
imu0_linear_acceleration_rejection_threshold: 0.8
imu0_remove_gravitational_acceleration: true
use_control: false
stamped_control: false
control_timeout: 0.2
control_config: [true, false, false, false, false, true]
acceleration_limits: [1.3, 0.0, 0.0, 0.0, 0.0, 3.4]
deceleration_limits: [1.3, 0.0, 0.0, 0.0, 0.0, 4.5]
acceleration_gains: [0.8, 0.0, 0.0, 0.0, 0.0, 0.9]
deceleration_gains: [1.0, 0.0, 0.0, 0.0, 0.0, 1.0]
process_noise_covariance: [0.05, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0,
0.0, 0.05, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0,
0.0, 0.0, 0.06, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0,
0.0, 0.0, 0.0, 0.03, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0,
0.0, 0.0, 0.0, 0.0, 0.03, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0,
0.0, 0.0, 0.0, 0.0, 0.0, 0.06, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0,
0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.025, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0,
0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.025, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0,
0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.04, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0,
0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.01, 0.0, 0.0, 0.0, 0.0, 0.0,
0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.01, 0.0, 0.0, 0.0, 0.0,
0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.02, 0.0, 0.0, 0.0,
0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.01, 0.0, 0.0,
0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.01, 0.0,
0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.015]
initial_estimate_covariance: [1e-9, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0,
0.0, 1e-9, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0,
0.0, 0.0, 1e-9, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0,
0.0, 0.0, 0.0, 1e-9, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0,
0.0, 0.0, 0.0, 0.0, 1e-9, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0,
0.0, 0.0, 0.0, 0.0, 0.0, 1e-9, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0,
0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 1e-9, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0,
0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 1e-9, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0,
0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 1e-9, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0,
0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 1e-9, 0.0, 0.0, 0.0, 0.0, 0.0,
0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 1e-9, 0.0, 0.0, 0.0, 0.0,
0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 1e-9, 0.0, 0.0, 0.0,
0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 1e-9, 0.0, 0.0,
0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 1e-9, 0.0,
0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 1e-9]
edit: added EFK node
imu_data (topic) output below
header:
stamp:
sec: 1732770428
nanosec: 327322667
frame_id: imu_link
orientation:
x: -0.03497527912259102
y: 0.07251419126987457
z: -0.8936092257499695
w: 0.44167736172676086
orientation_covariance:
- 0.0
- 0.0
- 0.0
- 0.0
- 0.0
- 0.0
- 0.0
- 0.0
- 0.0
angular_velocity:
x: 0.0625
y: 0.0625
z: 0.0625
angular_velocity_covariance:
- 0.0
- 0.0
- 0.0
- 0.0
- 0.0
- 0.0
- 0.0
- 0.0
- 0.0
linear_acceleration:
x: -0.10999999940395355
y: -0.009999999776482582
z: -0.07000000029802322
linear_acceleration_covariance:
- 0.0
- 0.0
- 0.0
- 0.0
- 0.0
- 0.0
- 0.0
- 0.0
- 0.0
Below echo from /odom
header:
stamp:
sec: 1732770536
nanosec: 999883669
frame_id: /odom
child_frame_id: base_footprint
pose:
pose:
position:
x: 0.007230392816932821
y: 0.0007949371304678404
z: 0.0
orientation:
x: 0.0
y: 0.0
z: 0.03194644236682118
w: 0.9994895821468592
covariance:
- 0.0
- 0.0
- 0.0
- 0.0
- 0.0
- 0.0
- 0.0
- 0.0
- 0.0
- 0.0
- 0.0
- 0.0
- 0.0
- 0.0
- 0.0
- 0.0
- 0.0
- 0.0
- 0.0
- 0.0
- 0.0
- 0.0
- 0.0
- 0.0
- 0.0
- 0.0
- 0.0
- 0.0
- 0.0
- 0.0
- 0.0
- 0.0
- 0.0
- 0.0
- 0.0
- 0.0
twist:
twist:
linear:
x: 5.890486225480862e-05
y: 0.0
z: 0.0
angular:
x: 0.0
y: 0.0
z: -0.00021381075228605668
covariance:
- 0.0
- 0.0
- 0.0
- 0.0
- 0.0
- 0.0
- 0.0
- 0.0
- 0.0
- 0.0
- 0.0
- 0.0
- 0.0
- 0.0
- 0.0
- 0.0
- 0.0
- 0.0
- 0.0
- 0.0
- 0.0
- 0.0
- 0.0
- 0.0
- 0.0
- 0.0
- 0.0
- 0.0
- 0.0
- 0.0
- 0.0
- 0.0
- 0.0
- 0.0
- 0.0
- 0.0
/odom
and/imu_data
. If you can do aros2 topic echo
on each of those topics and paste one sample message from each of them in the question, that would be great. $\endgroup$
