I'm in the process of tuning a robot-localization package parameters in my sensor-fusion ROS2 package. I have a dataset from various sensors mounted on a vehicle (IMU, GNSS, Lidar, Rgb Cameras, Radar, ...) without a direct odometry input from the vehicle.
The RTK GNSS I'm using has a 20Hz output, Imu publishes with a frequency of > 300Hz. That said, I'm using a combo of ekf_node and navsat_transform_node according to tutorial where the GNSS is converted into odometry/gps relatively. I've got no map frame.
I'd like to maximize the output frequency of the package possibly up to the frequency of the IMU if this can be handled computationally (or if it even makes sense?).
I've been increasing the frequency param of the ekf_filter_node, but at around 60Hz the actual output drops down abruptly to only around 5Hz. Fiddling around with parameters that I've felt could decrease the computational time yields basically no additional FPS.
This is my config file and a relevant part of the launch file:
ekf_filter_node:
  ros__parameters:
    frequency: 100.0
    sensor_timeout: 0.001
    two_d_mode: false
    reset_on_time_jump: true
    print_diagnostics: false
    debug: false
    publish_tf: true
    publish_acceleration: false
    odom_frame: odom
    base_link_frame: imu
    world_frame: odom
    odom0: odometry/gps
    odom0_config: [ true,  true,  true,
                    false, false, false,
                    false, false, false ]
    odom0_queue_size: 1
    odom0_nodelay: false
    odom0_differential: false
    odom0_relative: true
    imu0: imu/data
    imu0_config: [ false, false, false,
                   true,  true,  true,
                   true,  true,  true,
                   true,  true,  true ]
    imu0_nodelay: true
    imu0_differential: false
    imu0_relative: false
    imu0_queue_size: 1
    imu0_remove_gravitational_acceleration: true
    use_control: false
    process_noise_covariance: [0.01,    0.0,    0.0,    0.0,    0.0,    0.0,    0.0,     0.0,     0.0,    0.0,    0.0,    0.0,    0.0,    0.0,    0.0,
                               0.0,    0.01,    0.0,    0.0,    0.0,    0.0,    0.0,     0.0,     0.0,    0.0,    0.0,    0.0,    0.0,    0.0,    0.0,
                               0.0,    0.0,    0.01,    0.0,    0.0,    0.0,    0.0,     0.0,     0.0,    0.0,    0.0,    0.0,    0.0,    0.0,    0.0,
                               0.0,    0.0,    0.0,    0.01,    0.0,    0.0,    0.0,     0.0,     0.0,    0.0,    0.0,    0.0,    0.0,    0.0,    0.0,
                               0.0,    0.0,    0.0,    0.0,    0.01,    0.0,    0.0,     0.0,     0.0,    0.0,    0.0,    0.0,    0.0,    0.0,    0.0,
                               0.0,    0.0,    0.0,    0.0,    0.0,    0.01,    0.0,     0.0,     0.0,    0.0,    0.0,    0.0,    0.0,    0.0,    0.0,
                               0.0,    0.0,    0.0,    0.0,    0.0,    0.0,    0.1,     0.0,     0.0,    0.0,    0.0,    0.0,    0.0,    0.0,    0.0,
                               0.0,    0.0,    0.0,    0.0,    0.0,    0.0,    0.0,     0.1,     0.0,    0.0,    0.0,    0.0,    0.0,    0.0,    0.0,
                               0.0,    0.0,    0.0,    0.0,    0.0,    0.0,    0.0,     0.0,     0.1,    0.0,    0.0,    0.0,    0.0,    0.0,    0.0,
                               0.0,    0.0,    0.0,    0.0,    0.0,    0.0,    0.0,     0.0,     0.0,    0.1,    0.0,    0.0,    0.0,    0.0,    0.0,
                               0.0,    0.0,    0.0,    0.0,    0.0,    0.0,    0.0,     0.0,     0.0,    0.0,    0.1,    0.0,    0.0,    0.0,    0.0,
                               0.0,    0.0,    0.0,    0.0,    0.0,    0.0,    0.0,     0.0,     0.0,    0.0,    0.0,    0.1,    0.0,    0.0,    0.0,
                               0.0,    0.0,    0.0,    0.0,    0.0,    0.0,    0.0,     0.0,     0.0,    0.0,    0.0,    0.0,    0.1,    0.0,    0.0,
                               0.0,    0.0,    0.0,    0.0,    0.0,    0.0,    0.0,     0.0,     0.0,    0.0,    0.0,    0.0,    0.0,    0.1,    0.0,
                               0.0,    0.0,    0.0,    0.0,    0.0,    0.0,    0.0,     0.0,     0.0,    0.0,    0.0,    0.0,    0.0,    0.0,    0.1]
    initial_estimate_covariance: [1.0,    0.0,    0.0,    0.0,    0.0,    0.0,    0.0,    0.0,    0.0,    0.0,     0.0,     0.0,     0.0,    0.0,    0.0,
                                  0.0,    1.0,    0.0,    0.0,    0.0,    0.0,    0.0,    0.0,    0.0,    0.0,     0.0,     0.0,     0.0,    0.0,    0.0,
                                  0.0,    0.0,    1.0,    0.0,    0.0,    0.0,    0.0,    0.0,    0.0,    0.0,     0.0,     0.0,     0.0,    0.0,    0.0,
                                  0.0,    0.0,    0.0,    1.0,    0.0,    0.0,    0.0,    0.0,    0.0,    0.0,     0.0,     0.0,     0.0,    0.0,    0.0,
                                  0.0,    0.0,    0.0,    0.0,    1.0,    0.0,    0.0,    0.0,    0.0,    0.0,     0.0,     0.0,     0.0,    0.0,    0.0,
                                  0.0,    0.0,    0.0,    0.0,    0.0,    1.0,    0.0,    0.0,    0.0,    0.0,     0.0,     0.0,     0.0,    0.0,    0.0,
                                  0.0,    0.0,    0.0,    0.0,    0.0,    0.0,    1.0,    0.0,    0.0,    0.0,     0.0,     0.0,     0.0,    0.0,    0.0,
                                  0.0,    0.0,    0.0,    0.0,    0.0,    0.0,    0.0,    1.0,    0.0,    0.0,     0.0,     0.0,     0.0,    0.0,    0.0,
                                  0.0,    0.0,    0.0,    0.0,    0.0,    0.0,    0.0,    0.0,    1.0,    0.0,     0.0,     0.0,     0.0,    0.0,    0.0,
                                  0.0,    0.0,    0.0,    0.0,    0.0,    0.0,    0.0,    0.0,    0.0,    1.0,     0.0,     0.0,     0.0,    0.0,    0.0,
                                  0.0,    0.0,    0.0,    0.0,    0.0,    0.0,    0.0,    0.0,    0.0,    0.0,     1.0,     0.0,     0.0,    0.0,    0.0,
                                  0.0,    0.0,    0.0,    0.0,    0.0,    0.0,    0.0,    0.0,    0.0,    0.0,     0.0,     1.0,     0.0,    0.0,    0.0,
                                  0.0,    0.0,    0.0,    0.0,    0.0,    0.0,    0.0,    0.0,    0.0,    0.0,     0.0,     0.0,     1.0,    0.0,    0.0,
                                  0.0,    0.0,    0.0,    0.0,    0.0,    0.0,    0.0,    0.0,    0.0,    0.0,     0.0,     0.0,     0.0,    1.0,    0.0,
                                  0.0,    0.0,    0.0,    0.0,    0.0,    0.0,    0.0,    0.0,    0.0,    0.0,     0.0,     0.0,     0.0,    0.0,    1.0]
navsat_transform_node:
  ros__parameters:
    frequency: 20.0
    delay: 0.0
    magnetic_declination_radians: 0.08726646  # For lat/long 49.2, 16.6
    yaw_offset: 1.570796327  # IMU reads 0 facing magnetic north, not east
    zero_altitude: false
    broadcast_cartesian_transform: false
    publish_filtered_gps: false
    use_odometry_yaw: false
    wait_for_datum: false
        Node(
            package='robot_localization',
            executable='ekf_node',
            name='ekf_filter_node',
            output='screen',
            parameters=[os.path.join(pathlib.Path().resolve(), 'params', 'ekf.yaml')],
            remappings=[('imu/data', config_yaml["raw_topics"]["imu"]["imu"])]
        Node(
            executable='navsat_transform_node',
            name='navsat_transform_node',
            output='screen',
            remappings=[('imu', config_yaml["raw_topics"]["imu"]["imu"]),
                        ('gps/fix', config_yaml["raw_topics"]["gnss"]["position"])]
I'm also adding the actual framerate and ROS2 graph as reported by the rqt
enter image description here
Happy to get any suggestions as to what could the bottleneck be and why the FPS drops significantly when I ask for ~60Hz and more.
