I have some Python code working that reads from a sensor connected to I2C.
As this works, I assume I have all my permissions set up correctly for the I2C interface.
I then wrote a ROS 2 wrapper for the Python code. When I try run (ros2 run
) this node I get a PermissionError as follows:
Traceback (most recent call last): File "/opt/ros/jazzy/lib/python3.12/site-packages/launch/actions/execute_local.py", line 569, in __execute_process transport, self._subprocess_protocol = await async_execute_process( ^^^^^^^^^^^^^^^^^^^^^^^^^^^^ File "/opt/ros/jazzy/lib/python3.12/site-packages/osrf_pycommon/process_utils/async_execute_process_asyncio/impl.py", line 139, in async_execute_process transport, protocol = await _async_execute_process_nopty( ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ File "/opt/ros/jazzy/lib/python3.12/site-packages/osrf_pycommon/process_utils/async_execute_process_asyncio/impl.py", line 45, in _async_execute_process_nopty transport, protocol = await loop.subprocess_exec( ^^^^^^^^^^^^^^^^^^^^^^^^^^^ File "/usr/lib/python3.12/asyncio/base_events.py", line 1744, in subprocess_exec transport = await self._make_subprocess_transport( ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ File "/usr/lib/python3.12/asyncio/unix_events.py", line 211, in _make_subprocess_transport transp = _UnixSubprocessTransport(self, protocol, args, shell, ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ File "/usr/lib/python3.12/asyncio/base_subprocess.py", line 36, in init self._start(args=args, shell=shell, stdin=stdin, stdout=stdout, File "/usr/lib/python3.12/asyncio/unix_events.py", line 820, in _start self._proc = subprocess.Popen( ^^^^^^^^^^^^^^^^^ File "/usr/lib/python3.12/subprocess.py", line 1026, in init self._execute_child(args, executable, preexec_fn, close_fds, File "/usr/lib/python3.12/subprocess.py", line 1840, in _execute_child self._posix_spawn(args, executable, env, restore_signals, File "/usr/lib/python3.12/subprocess.py", line 1784, in _posix_spawn self.pid = os.posix_spawn(executable, args, env, **kwargs) ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ PermissionError: [Errno 13] Permission denied:
(address to my node in ws/install) follows "Permission denied:"
Anyone have ideas or things I can try to debug?
I have done sudo rosdep fix-permissions
in the workspace.
The Python file is also executable.
Thanks.
[Jazzy, RaspberryPi5]
