Description
I have installed ROS 2 Jazzy on Ubuntu 22.04.
If I just ros2 topic list and ros2 run demo_nodes_cpp talker on the same PC it works.
But if I want to see topics from another PC, it fails after setting the variables below:
export RMW_IMPLEMENTATION=rmw_cyclonedds_cpp
export CYCLONEDDS_URI=/path/to/my/cyclonedds.xml
After exporting this, any ros2 commands fail.
*** buffer overflow detected ***: terminated
ros2 topic list
Aborted (core dumped)
If I run ros2 daemon stop I don't have any errors, but as soon as I try ros2 topic list again I have the same error.
My cyclonedds.xml file is as follows:
<?xml version="1.0" encoding="UTF-8" ?>
<CycloneDDS xmlns="https://cdds.io/config" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:schemaLocation="https://cdds.io/config https://raw.githubusercontent.com/eclipse-cyclonedds/cyclonedds/master/etc/cyclonedds.xsd">
    <Domain id="any">
        <General>
            <AllowMulticast>false</AllowMulticast>
            <MaxMessageSize>6550B</MaxMessageSize>
            <FragmentSize>4000B</FragmentSize>
            <Transport>udp6</Transport>
        </General>
        <Discovery>
            <Peers>
 <Peer address="remote-pc"/>
 <Peer address="IPV6-HUSARNET-IP-OF-REMOTE-PC"/>
 <Peer address="IPV6-HUSARNET-IP-OF-LOCAL-PC"/>
 <Peer address="husarnet-local"/>
  <Peer address="master"/>
            </Peers>
            <MaxAutoParticipantIndex>100</MaxAutoParticipantIndex>
            <ParticipantIndex>auto</ParticipantIndex>
        </Discovery>
        <Internal>
            <Watermarks>
                <WhcHigh>500kB</WhcHigh>
            </Watermarks>
        </Internal>
        <Tracing>
            <Verbosity>severe</Verbosity>
            <OutputFile>stdout</OutputFile>
        </Tracing>
    </Domain>
</CycloneDDS>
It is worth mentioning that the IPV6 is obtained through Husarnet:
If I try the same thing using ROS 2 Humble, Galactic, or Iron, I don't have this problem. It only happens with Jazzy. Also, I tested RMW_IMPLEMENTATION=rmw_fastrtps_cpp and with fastrtps I don't have this error. The problem seems to be only with Cyclone DDS.
$ export RMW_IMPLEMENTATION=rmw_fastrtps_cpp
$ ros2 run demo_nodes_cpp talker
[INFO] [1718658361.109334174] [talker]: Publishing: 'Hello World: 1'
[INFO] [1718658362.109322134] [talker]: Publishing: 'Hello World: 2'
The problem seems to be in a method called dds_create_domain, as we can see in the bottom of the highlighted section in the screenshot below:
dds_create_domain call
Also, in the next screenshot, we can see the command line that causes the error. The screenshot is of the "Crash Error Report" tool on Ubuntu:
command line
Does anybody have any clues on what could be the reason behind this?
I found the solution.
I just compiled CycloneDDS from source and the problem went away automatically.
The link where I found the instructions on how to compile from source for ROS 2 Jazzy is the following:
https://docs.ros.org/en/foxy/Installation/DDS-Implementations/Working-with-Eclipse-CycloneDDS.html
The commands I used for compiling it from source can be summarized as follows:
mkdir -pv ~/ros2_ws/src
cd ~/ros2_ws/src
source /opt/ros/jazzy/setup.bash
source ~/ros2_ws/install/setup.bash
git clone https://github.com/ros2/rmw_cyclonedds ros2/rmw_cyclonedds -b jazzy
git clone https://github.com/eclipse-cyclonedds/cyclonedds -b 0.10.5 eclipse-cyclonedds/cyclonedds
cd ..
rosdep install -i --from-path src --rosdistro jazzy -y
colcon build
After that, I just sourced the ros2_ws and it worked as expected:
ros2 run demo_nodes_py talker
It is worth mentioning that I didn't make any changes to the code. I just compiled it from source and it worked.
