I have a Clearpath Husky A200 with two choices for the control PC
- Intel NUC (amd64) does not have a DP9 port by default but can be added
- Jetson Orin NX (arm64) having serial connections on board
I know that officially clearpath does not support arm64 architecture for husky at the time of writing this post. But I wanted to ask, is it possible to just connect with husky's MCU and see the green light on COMM
without using the USB-RS232 serial converter cable.
My current setup details are as below.
- Using Jetson Orin NX with Jetpack 6.0 (Ubuntu 22.04 + ROS2 humble installed)
- Using the ports at jetson's back (tx, rx, and gnd) as per instructions here to connect with rx, tx, and gnd respectively to DB9 male to female extension cable
- I used the pinout information from: for jetson and page 7, female DB9 connection from Clearpath Communication Protocol In this way, TX is connected to RX and vice-versa.
- I also noticed that the clearpath package expects the port to be
/dev/clearpath/prolific
. Theclearpath
directory was not present. So, I made a symlink to/dev/ttyTHS1
For arm64, not all ros-humble-clearpath-*
packages are built. So, I built the ros packages from source without errors.
However, I don't see any successful connection to the robot's MCU.
Below is my partial robot.yaml
file. Rest is the sensor information that I don't care as of now.:
serial_number: a200-0000
# serial_number: a200-0524
version: 0
system:
username: nvidia
# username: administrator
hosts:
# - hostname: cpr-a200-0000
- hostname: echo-jetson-orin-nx
ip: 192.168.131.1
ros2:
namespace: a200_0000
# namespace: a200_0524
domain_id: 0
middleware:
implementation: rmw_fastrtps_cpp
workspaces: ['/home/nvidia/ros2_ws/install/setup.bash']
I didn't see any systemctl service log that provides any error information about being not able to connect with the MCU.
I found another post where people faced similar issue (I guess they used usb to serial cable) but were turned down by the support people at the end.
Does anyone know, is it even possible to totally avoid the usb to serial cable and use RS232 directly instead? If yes, how could I debug further and solve this?
If not, I think I have to use the only Prolific USB to RS232 cable that I have for which drivers are not enabled in Jetpack 6.0 by default (might require kernel modification perhaps).
