I'm a new robot developer and I am learning ROS2, and I'm working on a project where I want to make a robot go straight to a specific area using GPS and IMU data. Since there won't be any obstacles around the robot, I don't need additional sensors like LIDAR or cameras. However, the biggest challenge I'm facing is that I can't generate odometry with GPS and IMU data, and I can't visualize this data in RViz.
Currently, I'm using GPS and IMU sensors to determine the robot's position and orientation. However, I'm struggling to convert this data into odometry and then visualize it using RViz. I need your help to figure out the steps to ensure the robot goes smoothly to a specific area without odometry.
I tried ekf with robot_localization but imu and gps data did not enter odometry. I tried to write it myself without success
ekf.yaml file:
# For parameter descriptions, please refer to the template parameter files for each node.
ekf_filter_node_odom:
ros__parameters:
frequency: 30.0
two_d_mode: true # Recommended to use 2d mode for nav2 in mostly planar environments
print_diagnostics: true
debug: false
publish_tf: true
map_frame: map
odom_frame: odom
base_link_frame: base_link # the frame id used by the turtlebot's diff drive plugin
world_frame: odom
odom0: gps
odom0_config: [false, false, false,
true, true, true,
false, false, true,
false, false, false]
odom0_queue_size: 10
odom0_differential: false
odom0_relative: false
imu0: imu
imu0_config: [false, false, false,
false, false, true,
imu0_differential: false # If using a real robot you might want to set this to true, since usually absolute measurements from real imu's are not very accurate
imu0_relative: false
imu0_queue_size: 10
imu0_remove_gravitational_acceleration: true
use_control: false
process_noise_covariance: [1e-3, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0,
0.0, 1e-3, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0,
0.0, 0.0, 1e-3, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0,
0.0, 0.0, 0.0, 0.3, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0,
0.0, 0.0, 0.0, 0.0, 0.3, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0,
0.0, 0.0, 0.0, 0.0, 0.0, 0.01, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0,
0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.5, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0,
0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.5, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0,
0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.1, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0,
0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.3, 0.0, 0.0, 0.0, 0.0, 0.0,
0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.3, 0.0, 0.0, 0.0, 0.0,
0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.3, 0.0, 0.0, 0.0,
0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.3, 0.0, 0.0,
0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.3, 0.0,
0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.3]
ekf_filter_node_map:
ros__parameters:
frequency: 30.0
debug: false
publish_tf: true
map_frame: map
odom_frame: odom
world_frame: map
# odom0: gps
# odom0_config: [false, false, false,
# false, false, false,
# true, true, true,
# false, false, true,
# false, false, false]
# odom0_queue_size: 10
# odom0_differential: false
# odom0_relative: false
odom0: gps
odom0_config: [true, true, false,
true, true, true,
false, false, true,
imu0: imu
false, false, true,
imu0_queue_size: 10
use_control: false
process_noise_covariance: [1.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0,
0.0, 1.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0,
navsat_transform:
ros__parameters:
frequency: 30.0
delay: 3.0
magnetic_declination_radians: 0.0
yaw_offset: 0.0
zero_altitude: true
broadcast_utm_transform: true
publish_filtered_gps: true
use_odometry_yaw: true
wait_for_datum: false
and launch.py file:
import os
from ament_index_python.packages import get_package_share_directory
from launch.actions import DeclareLaunchArgument
from launch.substitutions import Command, LaunchConfiguration
from launch_ros.actions import Node
from launch_ros.parameter_descriptions import ParameterValue
import launch_ros
start_ekf_local = Node(
package='robot_localization',
executable='ekf_node',
name='ekf_filter_node_odom',
output='screen',
parameters=[os.path.join(pkg_share, 'config/dual_ekf_navsat.yaml')],
remappings=[('odometry/filtered', 'odometry/local')]
start_ekf_global = Node(
name='ekf_filter_node_map',
output='screen',
remappings=[('odometry/filtered', 'odometry/global')]
navsat_transform= Node(
executable='navsat_transform_node',
name='navsat_transform',
output='screen',
remappings=[('gps/fix', 'gps')]
return LaunchDescription([
start_ekf_local,
start_ekf_global,
navsat_transform
