I have a differential drive robot, it is a 4wd robot, 2 motors, 2 encoders,s it behaves like a differential robot actually. Odometry from encoders is working well. I'm using ROS2 Humble on ubuntu 22.04.
I want to fuse odom, with an IMU to get a nice 2d pose (lokalisation)
So, I have done all the transform and got the odom and IMU topics. Which are the followings ODOM topic:
header: stamp: sec: 1708934625 nanosec: 68893329 frame_id: odom child_frame_id: laser_link pose: pose: position: x: 0.9908038973808289 y: -3.18342661857605 z: 0.0 orientation: x: 0.0 y: 0.0 z: 0.808424464005272 w: 0.5885999371370919 covariance:
8.632683822477702e-05 0.0 0.0 0.0 0.0 0.0 0.0 8.632683822477702e-05 0.0 0.0 0.0 0.0 0.0 0.0 8.632683822477702e-05 0.0 0.0 0.0 0.0 0.0 0.0 8.632683822477702e-06 0.0 0.0 0.0 0.0 0.0 0.0 8.632683822477702e-06 0.0 0.0 0.0 0.0 0.0 0.0 8.632683822477702e-06 twist: twist: linear: x: 0.05744318664073944 y: -0.010725230909883976 z: 0.0 angular: x: 0.0 y: -0.0 z: 0.046282440423965454 covariance: 4.316341911238851e-05 0.0 0.0 0.0 0.0 0.0 0.0 4.316341911238851e-05 0.0 0.0 0.0 0.0 0.0 0.0 4.316341911238851e-05 0.0 0.0 0.0 0.0 0.0 0.0 4.316341911238851e-06 0.0 0.0 0.0 0.0 0.0 0.0 4.316341911238851e-06 0.0 0.0 0.0 0.0 0.0 0.0 4.316341911238851e-06
AND IMU topic
header: stamp: sec: 1708934700 nanosec: 58079488 frame_id: camera_imu_optical_frame orientation: x: -0.564959732796857 y: -0.32758730601200314 z: 0.3634408670297931 w: 0.664392800555917 orientation_covariance:
0.0004 0.0 0.0 0.0 0.0004 0.0 0.0 0.0 0.0004
angular_velocity: x: 0.0 y: -0.006981316953897476 z: 0.0 angular_velocity_covariance: 0.01 0.0 0.0 0.0 0.01 0.0 0.0 0.0 0.01 linear_acceleration: x: 0.22555294632911682 y: -9.728196144104004 z: 1.4808040857315063 linear_acceleration_covariance: 1.0 0.0 0.0 0.0 1.0 0.0 0.0 0.0 1.0
So Im not sure about the correct EKF yamil config file.
My suggestion was this config
odom0: /odom/icp odom0_config: [true, true, true, # pose position (x, y, z) true, true, true, true, # pose orientation (quaternion x, y, z, w) false, false, false, false, false, false, # pose covariance true, true, false]
imu0: /imu/data
imu0_config: [false, false, false,
              true,  true,  false,
              false, true, false,
              true, true, false]
But not sure if the correct one. Any help?
This is documented very well at robot_localiztion documentation page
