Ubuntu 22.04, ROS2 Humble
I have a blickfield lidar and they provide ROS2 foxy support. I have downloaded the blickfield_ros2_driver from their website and created a repository.
Aim: I want to get it working in ROS2 Humble
I am basically following their Readme. However when I do colcon build --symlink-install --cmake-clean-first, I get the following
[ash@bot] [~/ros2_ws] - colcon build --symlink-install --cmake-clean-first
Starting >>> ouster_sensor_msgs
Starting >>> blickfeld_driver
Starting >>> pmd_royale_ros
Starting >>> pmd_royale_ros_driver
Starting >>> pmd_royale_ros_examples
Finished <<< pmd_royale_ros [0.37s]
--- stderr: blickfeld_driver
CMake Deprecation Warning at /opt/ros/humble/share/rosidl_cmake/cmake/rosidl_target_interfaces.cmake:32 (message):
  Use rosidl_get_typesupport_target() and target_link_libraries() instead of
  rosidl_target_interfaces()
  CMakeLists.txt:102 (rosidl_target_interfaces)
WARNING: Target "blickfeld_driver_lib" requests linking to directory "/usr/include".  Targets may link only to libraries.  CMake is dropping the item.
WARNING: Target "blickfeld_driver_component" requests linking to directory "/usr/include".  Targets may link only to libraries.  CMake is dropping the item.
WARNING: Target "blickfeld_driver_node" requests linking to directory "/usr/include".  Targets may link only to libraries.  CMake is dropping the item.
WARNING: Target "blickfeld_driver_core" requests linking to directory "/usr/include".  Targets may link only to libraries.  CMake is dropping the item.
/home/ash/ros2_ws/src/ros2_blickfeld_driver/modules/ros_blickfeld_driver_core/src/blickfeld_driver_utils.cpp:14:10: fatal error: cv_bridge/cv_bridge.h: No such file or directory
   14 | #include <cv_bridge/cv_bridge.h>
compilation terminated.
gmake[2]: *** [modules/ros_blickfeld_driver_core/CMakeFiles/blickfeld_driver_core.dir/build.make:118: modules/ros_blickfeld_driver_core/CMakeFiles/blickfeld_driver_core.dir/src/blickfeld_driver_utils.cpp.o] Error 1
gmake[2]: *** Waiting for unfinished jobs....
In file included from /home/ash/ros2_ws/src/ros2_blickfeld_driver/modules/ros_blickfeld_driver_core/src/blickfeld_driver_point_cloud_parser.cpp:15:
/home/ash/ros2_ws/src/ros2_blickfeld_driver/modules/ros_blickfeld_driver_core/include/blickfeld_driver_core/blickfeld_driver_point_cloud_parser.h:16:10: fatal error: cv_bridge/cv_bridge.h: No such file or directory
   16 | #include <cv_bridge/cv_bridge.h>
gmake[2]: *** [modules/ros_blickfeld_driver_core/CMakeFiles/blickfeld_driver_core.dir/build.make:104: modules/ros_blickfeld_driver_core/CMakeFiles/blickfeld_driver_core.dir/src/blickfeld_driver_point_cloud_parser.cpp.o] Error 1
In file included from /home/ash/ros2_ws/src/ros2_blickfeld_driver/modules/ros_blickfeld_driver_core/include/blickfeld_driver_core/blickfeld_driver_core.h:24,
                 from /home/ash/ros2_ws/src/ros2_blickfeld_driver/modules/ros_blickfeld_driver_core/src/blickfeld_driver_core.cpp:17:
/home/ash/ros2_ws/src/ros2_blickfeld_driver/include/blickfeld_driver/blickfeld_driver_ros_types.h:14:10: fatal error: tf2_geometry_msgs/tf2_geometry_msgs.h: No such file or directory
   14 | #include <tf2_geometry_msgs/tf2_geometry_msgs.h>
gmake[2]: *** [modules/ros_blickfeld_driver_core/CMakeFiles/blickfeld_driver_core.dir/build.make:76: modules/ros_blickfeld_driver_core/CMakeFiles/blickfeld_driver_core.dir/src/blickfeld_driver_core.cpp.o] Error 1
In file included from /home/ash/ros2_ws/src/ros2_blickfeld_driver/modules/ros_blickfeld_driver_core/include/blickfeld_driver_core/blickfeld_driver_imu_parser.h:20,
                 from /home/ash/ros2_ws/src/ros2_blickfeld_driver/modules/ros_blickfeld_driver_core/src/blickfeld_driver_imu_parser.cpp:12:
gmake[2]: *** [modules/ros_blickfeld_driver_core/CMakeFiles/blickfeld_driver_core.dir/build.make:90: modules/ros_blickfeld_driver_core/CMakeFiles/blickfeld_driver_core.dir/src/blickfeld_driver_imu_parser.cpp.o] Error 1
gmake[1]: *** [CMakeFiles/Makefile2:727: modules/ros_blickfeld_driver_core/CMakeFiles/blickfeld_driver_core.dir/all] Error 2
gmake[1]: *** Waiting for unfinished jobs....
gmake: *** [Makefile:146: all] Error 2
Failed   <<< blickfeld_driver [3.54s, exited with code 2]
Aborted  <<< ouster_sensor_msgs [3.57s]
Aborted  <<< pmd_royale_ros_examples [8.83s]
Aborted  <<< pmd_royale_ros_driver [10.2s]
Summary: 1 package finished [10.7s]
  1 package failed: blickfeld_driver
  3 packages aborted: ouster_sensor_msgs pmd_royale_ros_driver pmd_royale_ros_examples
  1 package had stderr output: blickfeld_driver
  1 package not processed
I think the CMakeLists.txt has properly linked to both cv_bridge and tf2_geometry_msgs. I even tried to change the .h to .hpp but did not work.
I have already done sudo apt install ros-humble-cv-bridge/tf2-geometry-msgs. Something I observed is that if I go to /opt/ros/humble/include/, all the similar msgs are under a msg folder where as tf2-geometry-msgs are not. Is my installation okay?
Any help would be really appreciated. TIA
hope my reply is not too late :)
I met the same issue as you. After searching on the Internet, I found the solution.
The reason for the issue
The reason for the error is that the CMake cannot find the path of cv_bridge and tf2_geometry_msgs. In the CMakeLists.txt, it doesn't specify the including for dirs of cv_bridge and tf2_geometry_msgs.
Solution
  1. add include_directories in CMakeLists.txt like this: https://github.com/NEWSLabNTU/liteon_ros2_blickfeld_driver_src-v1.5.5/blob/main/CMakeLists.txt#L82-L96
  2. Or, you can use target_inculde_directories and target_link_libraries to specify the dirs and libs of cv2_bridge and tf2_geometry_msgs. A reference can be seen here: https://github.com/Blickfeld/blickfeld_qb2_ros2_driver/blob/main/CMakeLists.txt#L64-L79
