I'm building moveit2 from this tutorial: moveit2_tutorials.picknik.ai/doc/getting_started/getting_started.html
I'm on Ubuntu 20.04 and my ros2 version is foxy, which was built from debian. Rosdep returns all rosdeps installed successfully and moveit2's repos have been successfully cloned.
I'm getting this when building:
--- stderr: moveit_ros_warehouse /usr/bin/ld: libmoveit_warehouse.so.: undefined reference to `MD5' collect2: error: ld returned 1 exit status
Here is the code from colcon build:
:~/robotics/moveo_ws/ws$ colcon build --event-handlers desktop_notification- status- >--cmake-args -DCMAKE_BUILD_TYPE=Release
Starting >>> geometric_shapes [Processing: geometric_shapes] [Processing: geometric_shapes] [Processing: geometric_shapes] [Processing: geometric_shapes] Finished <<< geometric_shapes [2min 1s] Starting >>> moveit_msgs Finished <<< moveit_msgs [7.18s] Starting >>> srdfdom Finished <<< srdfdom [0.52s] Starting >>> moveit_common Finished <<< moveit_common [0.27s] Starting >>> controller_manager_msgs Finished <<< controller_manager_msgs [2.03s] Starting >>> ros2_control_test_assets Finished <<< ros2_control_test_assets [0.25s] Starting >>> hardware_interface Finished <<< hardware_interface [0.98s] Starting >>> controller_interface Finished <<< controller_interface [0.66s] Starting >>> controller_manager Finished <<< controller_manager [1.18s] Starting >>> warehouse_ros Finished <<< warehouse_ros [0.45s] Starting >>> moveit_resources_panda_description Finished <<< moveit_resources_panda_description [0.26s] Starting >>> moveit_resources_panda_moveit_config Finished <<< moveit_resources_panda_moveit_config [0.28s] Starting >>> moveit_resources_fanuc_description Finished <<< moveit_resources_fanuc_description [0.26s] Starting >>> moveit_resources_fanuc_moveit_config Finished <<< moveit_resources_fanuc_moveit_config [0.27s] Starting >>> forward_command_controller Finished <<< forward_command_controller [0.63s] Starting >>> moveit_resources_pr2_description Finished <<< moveit_resources_pr2_description [0.30s] Starting >>> moveit_core Finished <<< moveit_core [4.59s] Starting >>> moveit_ros_occupancy_map_monitor Finished <<< moveit_ros_occupancy_map_monitor [0.48s] Starting >>> moveit_ros_planning Finished <<< moveit_ros_planning [2.06s] Starting >>> moveit_kinematics Finished <<< moveit_kinematics [0.98s] Starting >>> moveit_ros_warehouse --- stderr: moveit_ros_warehouse /usr/bin/ld: libmoveit_warehouse.so.: undefined reference to `MD5' collect2: error: ld returned 1 exit status make[2]: *** [warehouse/CMakeFiles/moveit_warehouse_broadcast.dir/build.make:346: warehouse/moveit_warehouse_broadcast] Error 1 make[1]: *** [CMakeFiles/Makefile2:189: warehouse/CMakeFiles/moveit_warehouse_broadcast.dir/all] Error 2 make: *** [Makefile:141: all] Error 2
Failed <<< moveit_ros_warehouse [1.37s, exited with code 2]
Summary: 20 packages finished [2min 27s] 1 package failed: moveit_ros_warehouse 1 package had stderr output: moveit_ros_warehouse 33 packages not processed
I see this and look closer at ws/build/moveit_ros_warehouse/CMakeFiles and cat CMakeError.log. Here is the cat:
Performing C SOURCE FILE Test CMAKE_HAVE_LIBC_PTHREAD failed with the >following output: Change Dir: /home/forrest/robotics/moveo_ws/ws/build/moveit_ros_warehouse/CMakeFiles/CMakeTmp
Run Build Command(s):/usr/bin/make cmTC_6c77e/fast && /usr/bin/make -f CMakeFiles/cmTC_6c77e.dir /build.make CMakeFiles/cmTC_6c77e.dir/build make[1]: Entering directory '/home/forrest/robotics/moveo_ws/ws/build/moveit_ros_warehouse/CMakeFile/CMakeTmp' Building C object CMakeFiles/cmTC_6c77e.dir/src.c.o /usr/bin/cc -DCMAKE_HAVE_LIBC_PTHREAD -o CMakeFiles/cmTC_6c77e.dir/src.c.o -c /home/forrest/robotics/moveo_ws/ws/build/moveit_ros_warehouse/CMakeFiles/CMakeTmp/src.c Linking C executable cmTC_6c77e /usr/bin/cmake -E cmake_link_script CMakeFiles/cmTC_6c77e.dir/link.txt --verbose=1 /usr/bin/cc -DCMAKE_HAVE_LIBC_PTHREAD CMakeFiles/cmTC_6c77e.dir/src.c.o -o cmTC_6c77e /usr/bin/ld: CMakeFiles/cmTC_6c77e.dir/src.c.o: in function main': src.c:(.text+0x46): undefined reference to pthread_create' /usr/bin/ld: src.c:(.text+0x52): undefined reference to pthread_detach' /usr/bin/ld: src.c:(.text+0x63): undefined reference to pthread_join' collect2: error: ld returned 1 exit status make[1]: *** [CMakeFiles/cmTC_6c77e.dir/build.make:87: cmTC_6c77e] Error 1 make[1]: Leaving directory '/home/forrest/robotics/moveo_ws/ws/build/moveit_ros_warehouse/CMakeFile/CMakeTmp' make: *** [Makefile:121: cmTC_6c77e/fast] Error 2
Source file was: #include <pthread.h>
void* test_func(void* data) { return data; }
int main(void) { pthread_t thread; pthread_create(&thread, NULL, test_func, NULL); pthread_detach(thread); pthread_join(thread, NULL); pthread_atfork(NULL, NULL, NULL); pthread_exit(NULL);
return 0; }
Determining if the function pthread_create exists in the pthreads failed with the >following output: Change Dir: /home/forrest/robotics/moveo_ws/ws/build/moveit_ros_warehouse/CMakeFiles/CMakeTmp
Run Build Command(s):/usr/bin/make cmTC_9cb30/fast && /usr/bin/make -f >CMakeFiles/cmTC_9cb30.dir/build.make CMakeFiles/cmTC_9cb30.dir/build make[1]: Entering directory '/home/forrest/robotics/moveo_ws/ws/build/moveit_ros_warehouse/CMakeFiles/CMakeTmp' Building C object CMakeFiles/cmTC_9cb30.dir/CheckFunctionExists.c.o /usr/bin/cc -DCHECK_FUNCTION_EXISTS=pthread_create -o >CMakeFiles/cmTC_9cb30.dir/CheckFunctionExists.c.o -c /usr/share/cmake-3.16/Modules/CheckFunctionExists.c Linking C executable cmTC_9cb30 /usr/bin/cmake -E cmake_link_script CMakeFiles/cmTC_9cb30.dir/link.txt --verbose=1 /usr/bin/cc -DCHECK_FUNCTION_EXISTS=pthread_create >CMakeFiles/cmTC_9cb30.dir/CheckFunctionExists.c.o -o cmTC_9cb30 -lpthreads /usr/bin/ld: cannot find -lpthreads collect2: error: ld returned 1 exit status make[1]: *** [CMakeFiles/cmTC_9cb30.dir/build.make:87: cmTC_9cb30] Error 1 make[1]: Leaving directory '/home/forrest/robotics/moveo_ws/ws/build/moveit_ros_warehouse/CMakeFiles/CMakeTmp' make: *** [Makefile:121: cmTC_9cb30/fast] Error 2
Is this the error: /usr/bin/ld: cannot find -lpthreads? I checked online and people recommend not to use -l when working with pthreads. I'm new to c and don't know much about pthreads. I also don't know where to go about finding CMakeFiles/cmTC_9cb30.dir and changing -lpthreads to -pthread
Is the error the top half that says there are 3 undefined referrences to pthread functions?
Any guidance on this would be wonderfully appreciated.
Originally posted by Daggrosh on ROS Answers with karma: 28 on 2021-07-03
I just tried building it from source and I didn't have any error, can you share more info, which commits hash are you using for each package .? what's the output of echo $AMENT_PREFIX_PATH .? what's the output for the following command apt policy ros-foxy-warehouse-ros ros-foxy-warehouse-ros-mongo .?
Originally posted by jafar_abdi with karma: 221 on 2021-07-05
Comment by Daggrosh on 2021-07-05:
The ament prefix path output is: /opt/ros/foxy
The output for the apt policy is: ros-foxy-warehouse-ros: Installed: 2.0.1-1focal.20210601.182449 Candidate: 2.0.1-1focal.20210601.182449 Version table: *** 2.0.1-1focal.20210601.182449 500 500 http://packages.ros.org/ros2/ubuntu focal/main amd64 Packages 100 /var/lib/dpkg/status ros-foxy-warehouse-ros-mongo: Installed: 2.0.2-1focal.20210618.005428 Candidate: 2.0.2-1focal.20210618.005428 Version table: *** 2.0.2-1focal.20210618.005428 500 500 http://packages.ros.org/ros2/ubuntu focal/main amd64 Packages 100 /var/lib/dpkg/status
More information: I have built moveit2 up until the packages depending on moveit_ros_warehouse (which total 11 packages) using the --continue-on-error colcon command, so I have successfully installed warehouse_ros and warehouse_ros_mongo.
I have since tried to build moveit2 again in a fresh ws. Here are the exact steps, which ended with the same error:
mkdir moveit2_test cd moveit2_test git clone [email protected]:ros-planning/moveit2 #successful mv moveit2 src rosdep install -i -r --from-paths src --ignore src --rosdistro foxy -y #successful colcon build --event-handlers desktop_notification- status- --cmake-args -DCMAKE_BUILD_TYPE=Release #successful until moveit_ros_warehouse
error: --- stderr: moveit_ros_warehouse /usr/bin/ld: libmoveit_warehouse.so.: undefined reference to `MD5' collect2: error: ld returned 1 exit status make[2]: *** [warehouse/CMakeFiles/moveit_warehouse_broadcast.dir/build.make:346: warehouse/moveit_warehouse_broadcast] Error 1 make[1]: *** [CMakeFiles/Makefile2:189: warehouse/CMakeFiles/moveit_warehouse_broadcast.dir/all] Error 2 make: *** [Makefile:141: all] Error 2
I also got a stderror output for moveit_core, but it was a warning and don't think it's a big deal
Comment by jafar_abdi on 2021-07-06:
After debugging it further, I think this's due to a bug in ament_cmake where it does prefer the system installed package rather than the source one, if you remove these packages ros-foxy-warehouse-ros ros-foxy-warehouse-ros-mongo it should pass
Comment by Daggrosh on 2021-07-07:
It worked! You're magic man, thanks so much
