Ubuntu 22.04, ROS 2 Humble
Hi, I am following the official tutorial to pass arguments to a cpp node via a python launch file
https://docs.ros.org/en/humble/How-To-Guides/Launch-file-different-formats.html
My launch file is as follows
import os
# https://docs.ros.org/en/humble/How-To-Guides/Launch-file-different-formats.html
from launch.actions import DeclareLaunchArgument, LogInfo
from launch.actions import IncludeLaunchDescription
from launch.actions import GroupAction
from launch.launch_description_sources import PythonLaunchDescriptionSource
from launch.substitutions import LaunchConfiguration
from launch.substitutions import TextSubstitution
from launch_ros.actions import Node
from launch_ros.actions import PushRosNamespace
from ament_index_python.packages import get_package_share_directory #* Required to get YAML file
# Define path to package
home_directory = os.path.expanduser("~")
path_to_orbslam3_pck = home_directory + "/" + "ros2_ws/src/orb_slam3_ros2"
# Build global paths
voc_path = os.path.join(path_to_orbslam3_pck, 'orb_slam3/Vocabulary/ORBvoc.txt.bin')
settings_path = os.path.join(path_to_orbslam3_pck, 'orb_slam3/config/Monocular/')
# https://roboticscasual.com/tutorial-ros2-launch-files-all-you-need-to-know/#cmd-line-args-hand-over
ld = LaunchDescription()
# If you want to load some YAML files
# config_robot1 = os.path.join(
# get_package_share_directory('my_launcher'), #* Nothing fancy here, this is how the syntax goes
# 'config',
# 'params.yaml'
# voc_file_launch_arg = DeclareLaunchArgument(
# "voc_file",
# default_value=TextSubstitution(text=voc_path),
# # description='Path to the Vocabulary file for ORB-SLAM3',
# settings_file_path_launch_arg = DeclareLaunchArgument(
# "settings_file_path",
# default_value=TextSubstitution(text=settings_path),
# #description='Path to the Vocabulary file for ORB-SLAM3',
settings_file_name_launch_arg = DeclareLaunchArgument(
"settings_file_name",
default_value=TextSubstitution(text='file_not_set'), # EuRoC, TUM2
# description='Settings file name i.e. EuoRoC, TUM2 etc',
robot0_vslam_node = Node(
package="orb_slam3_ros2", # Remember, the (,) are very important
executable="agent0",
name = "robot0_vslam",
# # if you have a namespace, use this tutorial to add it https://www.youtube.com/watch?v=wY8MrBGVxYA
#parameters=[config_robot1] # when using YAML configuration files
#* List with tuples
parameters=[
{"agent_name_arg": 'robot0'},
#{"voc_file_arg": LaunchConfiguration('voc_file')},
#{"settings_file_path_arg": LaunchConfiguration('settings_file_path')},
{"settings_file_name_arg": LaunchConfiguration('settings_file_name')}
] # When setting individual parameters, set it as a tuple
# https://answers.ros.org/question/382167/is-it-possible-to-have-a-conditional-in-a-launch-file-using-declarelaunchargument/
#ld.add_action(voc_file_launch_arg)
#ld.add_action(settings_file_path_launch_arg)
ld.add_action(settings_file_name_launch_arg)
ld.add_action(robot0_vslam_node) # This adds the node to the description
return ld
This code builds without any issue. To make the testing simpler, I am only trying to pass one argument to my CPP node to see if it receives it.
However, when I try running this command
ros2 launch my_launcher my_app_launch.py settings_file_name:="TUM2"
I am getting this following error
[ERROR] [launch]: Caught exception in launch (see debug for traceback): 'tuple' object has no attribute 'describe_sub_entities'
Note that, I had tried returning LaunchDescription
in the following way
return LaunchDescription([
launch_args,
node
Both gives the error shown above.
My questions are the following
- What is `describe_sub_entities' in context of the above problem?
- What changes are required to get the desired behavior?
Thanks @Mechazo11
