Greetings. Is there a way to use arguments within launch files written in Python?
I have found the possibilities offered by roslaunch, however I was wondering how to achieve the same effect in Python launch files.
To be more specific I want to create a number of robots for simulation purposes. For this I would like to supply a list of pose coordinates, spawning the corresponding number of robots at the respective poses.
In order to achieve this I plan to iterate in the launch file to create separate namespaces for each robot before spawning them.
Therefore, is there a way to pass some command line arguments like ros2 launch my_sim_bringup multiple_robots.launch -x 0 -y 0 -z 0 ?
Could I define generate_launch_description like this def generate_launch_description(my_arg), as I would do with any Python function to achieve this behavior?
I am very sorry for asking such basic questions, but the documentation regarding the Python launch system is lacking.
EDIT: Doing further research I found: ros2 access current LaunchConfiguration, Access launch argument in LaunchFile ROS2 as well as ROS2: How to pass arguments from one launch file to a child launch file. But to be frank, I don't get it.
Using the method proposed by these links I have implemented in my launch file:
ld = LaunchDescription()
robot_positions = DeclareLaunchArgument(
            'positions',
            default_value="000",
ld.add_action(robot_positions)
as well as
positions = LaunchConfiguration('positions', default="000")
Now I was lead to belief that it was possible to use command line arguments or superordinate launch files to supply the values. Something like this for command line ros2 launch my_sim_bringup multiple_robots.launch positions:=000
However, positions does not hold the string "000", rather a LaunchConfiguration object, which as far as I can see it in launch_configuration.py has no getter functions for retrieving the value.
Originally posted by NotARobot on ROS Answers with karma: 109 on 2021-02-23
Comment by destogl on 2021-03-11:
Please have a look at this answer. Maybe it helps you.
Thank you for your answer destogl. I have to confess the solution I was looking for is very trivial and is more generic to Python.
I have solved the problem by using argv to get the desired effect.
Originally posted by NotARobot with karma: 109 on 2021-05-27
