Hi. Sorry for all mistakes, English is not my native language. So I'm launching my gazebo simulation with JointStateBroadcaster and DiffDrive controllers. Gazebo loads without notable errors but then controllers start to load I receive following logs in terminal:
[gzserver-6] [INFO] [1670244707.718918444] [gazebo_ros2_control]: Loading controller_manager
[gzserver-6] [WARN] [1670244707.830804032] [gazebo_ros2_control]: Desired controller update period (0.02 s) is slower than the gazebo simulation period (0.001 s).
[gzserver-6] [INFO] [1670244707.831187703] [gazebo_ros2_control]: Loaded gazebo_ros2_control.
[gzserver-6] [INFO] [1670244707.880241583] [controller_manager]: Loading controller 'minicar_cll'
[gzserver-6] [INFO] [1670244707.969517659] [controller_manager]: Setting use_sim_time=True for minicar_cll to match controller manager (see ros2_control#325 for details)
[spawner.py-3] [INFO] [1670244707.973501681] [spawner_minicar_cll]: Loaded minicar_cll
[gzserver-6] [INFO] [1670244707.977437769] [controller_manager]: Configuring controller 'minicar_cll'
[gzserver-6] [INFO] [1670244708.048451910] [controller_manager]: Loading controller 'joint_s_b'
[gzserver-6] [INFO] [1670244708.178457173] [controller_manager]: Setting use_sim_time=True for joint_s_b to match controller manager (see ros2_control#325 for details)
[spawner.py-5] [INFO] [1670244708.200924658] [spawner_joint_s_b]: Loaded joint_s_b
[gzserver-6] [INFO] [1670244708.204831040] [controller_manager]: Loading controller 'joint_s_b'
[gzserver-6] [ERROR] [1670244708.205196239] [controller_manager]: A controller named 'joint_s_b' was already loaded inside the controller manager
[gzserver-6] [ERROR] [1670244708.226174298] [controller_manager]: Can't activate controller 'minicar_cll': Command interface with 'front_left_steering_joint/velocity' does not exist
[spawner.py-3] [INFO] [1670244708.255965445] [spawner_minicar_cll]: Configured and started minicar_cll
[gzserver-6] [INFO] [1670244708.262011951] [controller_manager]: Configuring controller 'joint_s_b'
[ERROR] [spawner.py-2]: process has died [pid 5069, exit code 1, cmd '/opt/ros/foxy/lib/controller_manager/spawner.py joint_s_b --ros-args'].
[INFO] [spawner.py-3]: process has finished cleanly [pid 5071]
[spawner.py-5] [INFO] [1670244708.351449614] [spawner_joint_s_b]: Configured and started joint_s_b
[INFO] [spawner.py-5]: process has finished cleanly [pid 5075]
[INFO] [spawner.py-9]: process started with pid [5305]
[gzclient-7] context mismatch in svga_surface_destroy
[spawner.py-9] [INFO] [1670244708.899426522] [spawner_minicar_cll]: Controller already loaded, skipping load_controller
[gzserver-6] [INFO] [1670244708.902372504] [controller_manager]: Configuring controller 'minicar_cll'
[gzserver-6] [ERROR] [1670244708.998457025] [controller_manager]: Can't activate controller 'minicar_cll': Command interface with 'front_left_steering_joint/velocity' does not exist
[spawner.py-9] [INFO] [1670244709.020476614] [spawner_minicar_cll]: Configured and started minicar_cll
minicar_cll here is diff_drive controller.
Here is yaml file with controllers settings:
controller_manager:
ros__parameters:
update_rate: 50 # Hz
use_sim_time: True
joint_s_b:
type: joint_state_broadcaster/JointStateBroadcaster
minicar_cll:
type: diff_drive_controller/DiffDriveController
minicar_cll:
ros__parameters:
left_wheel_names: ['front_left_wheel_joint', 'rear_left_wheel_joint', 'front_left_steering_joint', 'rear_left_steering_joint']
right_wheel_names: ['front_right_wheel_joint', 'rear_right_wheel_joint', 'front_right_steering_joint', 'rear_right_steering_joint']
publish_rate: 50.0
pose_covariance_diagonal: [0.001, 0.001, 0.001, 0.001, 0.001, 0.03]
twist_covariance_diagonal: [0.001, 0.001, 0.001, 0.001, 0.001, 0.03]
cmd_vel_timeout: 0.5
wheels_per_side: 1
preserve_turning_radius: true
base_frame_id: rs_t265_pose_frame
enable_odom_tf: false
angular:
steer:
front_max_angle: 1.047
rear_max_angle: 0.0
And that is transmission description:
<transmission name="${wheel_prefix}_steering_trans" type="SimpleTransmission">
<type>transmission_interface/SimpleTransmission</type>
<actuator name="${wheel_prefix}_steering_motor">
<hardwareInterface>PositionJointInterface</hardwareInterface>
<mechanicalReduction>1</mechanicalReduction>
</actuator>
<joint name="${wheel_prefix}_steering_joint">
</joint>
</transmission>
<transmission name="${wheel_prefix}_wheel_trans" type="SimpleTransmission">
<actuator name="${wheel_prefix}_wheel_motor">
</actuator>
<joint name="${wheel_prefix}_wheel_joint">
<hardwareInterface>VelocityJointInterface</hardwareInterface>
</joint>
</transmission>
</xacro:macro>
and ros2_control tag in robot description with gazebo plugin
<ros2_control name="GazeboSystem" type="system">
<hardware>
<plugin>gazebo_ros2_control/GazeboSystem</plugin>
</hardware>
<joint name="front_left_steering_joint">
<command_interface name="position"/>
<state_interface name="position"/>
<state_interface name="velocity"/>
<state_interface name="effort"/>
</joint>
<joint name="front_right_steering_joint">
</joint>
<joint name="rear_left_steering_joint">
</joint>
<joint name="rear_right_steering_joint">
</joint>
<joint name="rear_right_wheel_joint">
<command_interface name="velocity"/>
</joint>
<joint name="rear_left_wheel_joint">
</joint>
<joint name="front_left_wheel_joint">
</joint>
<joint name="front_right_wheel_joint">
</joint>
</ros2_control>
<gazebo>
<plugin name="gazebo_ros2_control" filename="libgazebo_ros2_control.so">
<parameters>$(find minicar_control)/config/control.yaml</parameters>
</plugin>
</gazebo>
And my question is why is it trying to load JointStateBroadcaster several times and why is he complaining about "Command interface with 'front_left_steering_joint/velocity' does not exist"? Appreciate any help.
UPD. Add full terminal output and launch files used to start gazebo simulation.
Terminal:
This code block was moved to the following github gist: https://gist.github.com/answers-se-migration-openrobotics/cccb826d947e62e554eb61c37050efc3
launch file gazebo_world.launch.py:
import os
import xacro
from ament_index_python.packages import get_package_share_directory
from launch.actions import IncludeLaunchDescription
from launch.launch_description_sources import PythonLaunchDescriptionSource
from launch.substitutions import PathJoinSubstitution
from launch_ros.substitutions import FindPackageShare
from launch_ros.actions import Node
package_dir = os.path.join(get_package_share_directory('minicar_simulator'))
controller_file = os.path.join(get_package_share_directory('minicar_control'), "config", "control.yaml")
doc = os.path.join(package_dir, 'urdf', 'minicar.gazebo.xacro')
xacro_file = xacro.parse(open(doc))
xacro.process_doc(xacro_file)
robot_description = {"robot_description": xacro_file.toxml()}
world_file = PathJoinSubstitution(
[FindPackageShare("minicar_simulator"),
"worlds",
"test_walls.world"],
gazebo_launch = PathJoinSubstitution(
"launch",
"gazebo.launch.py"],
node_controller_manager = Node(
package="controller_manager",
executable="ros2_control_node",
parameters=[robot_description, controller_file],
output={
"stdout": "screen",
"stderr": "screen",
spawn_controller = Node(
executable="spawner.py",
arguments=["joint_s_b"],
output="screen",
spawn_diff_velocity_controller = Node(
arguments=["minicar_cll"],
output="screen",
gazebo_sim = IncludeLaunchDescription(
PythonLaunchDescriptionSource([gazebo_launch]),
launch_arguments={'world_path': world_file}.items(),
ld = LaunchDescription()
ld.add_action(node_controller_manager)
ld.add_action(spawn_controller)
ld.add_action(spawn_diff_velocity_controller)
ld.add_action(gazebo_sim)
return ld
launch file gazebo.launch.py:
import os
import xacro
from launch.actions import DeclareLaunchArgument, ExecuteProcess, RegisterEventHandler
from launch.event_handlers import OnProcessExit
from launch.substitutions import LaunchConfiguration
ARGUMENTS = [
DeclareLaunchArgument('world_path', default_value='',
description='The world path, by default is empty.world'),
DeclareLaunchArgument('verbose', default_value='true',
description='Set "true" to increase messages written to terminal.'),
# Launch args
world_path = LaunchConfiguration('world_path')
verbose = 'true'
package='controller_manager',
executable='spawner.py',
arguments=['minicar_cll', '-c', '/controller_manager'],
output='screen',
node_robot_state_publisher = Node(
package="robot_state_publisher",
executable="robot_state_publisher",
output="screen",
parameters=[{'use_sim_time': True}, robot_description],
spawn_joint_state_broadcaster = Node(
arguments=['joint_s_b', '-c', '/controller_manager'],
output='screen',
diffdrive_controller_spawn_callback = RegisterEventHandler(
event_handler=OnProcessExit(
target_action=spawn_joint_state_broadcaster,
on_exit=[spawn_diff_velocity_controller],
gzserver = ExecuteProcess(
cmd=['gzserver',
'-s', 'libgazebo_ros_init.so',
'-s', 'libgazebo_ros_factory.so',
world_path,
verbose],
output='screen',
# Gazebo client
gzclient = ExecuteProcess(
cmd=['gzclient'],
output='screen',
# Spawn robot
spawn_entity = Node(package='gazebo_ros', executable='spawn_entity.py',
arguments=['-topic', 'robot_description',
'-x', '-3.0',
'-y', '-1.5',
'-z', '2.719',
'-entity', 'minicar'],
output='screen')
ld = LaunchDescription(ARGUMENTS)
ld.add_action(node_robot_state_publisher)
ld.add_action(spawn_joint_state_broadcaster)
ld.add_action(diffdrive_controller_spawn_callback)
ld.add_action(gzserver)
ld.add_action(gzclient)
ld.add_action(spawn_entity)
return ld
I was told not to add full URDF description, so sorry for inconvenience, but I already double check my robot description and I didn't find any problem with it.
Originally posted by Edvard on ROS Answers with karma: 95 on 2022-12-05
