We're working on a modified version of the example "nav2_straightline_planner". Our goal is to plan a straight path from one waypoint to the next, without regard for the robot's position. This path is only changed after completing the current goal. As it is currently written, our Planner works as expected. We do not use obstacle avoidance of any kind, and do not plan to at the moment. The operating area of the robot is static.
My questions are:
- Is it bad practice to not use the current position of the bot when planning paths?
- Should paths always be planned from the origin of the robot without exception (base_link or similar)?
- Will allowing the robot to be "disconnected" from the planned path cause issues elsewhere (namely for the chosen Controller, RPP in our case)?
We've been running the robot in this current setup for weeks with pretty decent success. RPP does seem to need better tuning on our part to more closely follow the planned path.
It seems all of the provided Planners in the Navigation2 stack plan from the robots origin each iteration, unless I'm understanding that incorrectly.
Thank you
Originally posted by hapy-capy on ROS Answers with karma: 33 on 2022-11-01
