It seems a bit complicated but I managed to instantiate urdf::Model
by following the below steps:
- Get the value of
robot_description
as string: This requires extra effort. Remember, ROS 2 does not have a centralized parameter server. So, getting a parameter from another node is tricky. You can read more about the procedure at this link.
- Use the string as input to build URDF model: We can use
initString()
method.
Code
// license removed for brevity
#include <urdf/model.h>
#include <chrono>
#include <memory>
#include <rclcpp/rclcpp.hpp>
using namespace std::chrono_literals;
class MinimalPublisher : public rclcpp::Node
public:
MinimalPublisher() : Node("minimal_publisher")
parameters_client_ = std::make_shared<rclcpp::SyncParametersClient>(this, "/robot_state_publisher");
while (!parameters_client_->wait_for_service(1s))
if (!rclcpp::ok())
RCLCPP_ERROR(this->get_logger(), "Interrupted while waiting for the service. Exiting.");
rclcpp::shutdown();
RCLCPP_INFO(this->get_logger(), "Service not available, waiting again...");
std::string urdf_string;
auto parameters = parameters_client_->get_parameters({ "robot_description" });
for (auto& parameter : parameters)
if (parameter.get_name() == "robot_description")
urdf_string = parameter.value_to_string();
break;
urdf::Model urdfModel;
urdfModel.initString(urdf_string);
RCLCPP_INFO_STREAM(this->get_logger(), "Name:" << urdfModel.getName());
private:
std::shared_ptr<rclcpp::SyncParametersClient> parameters_client_;
int main(int argc, char* argv[])
rclcpp::init(argc, argv);
rclcpp::spin(std::make_shared<MinimalPublisher>());
rclcpp::shutdown();
return 0;
Run
First, I published a URDF using urdf_tutorial. Please see the command below:
ravi@dell:~$ ros2 launch urdf_tutorial display.launch.py model:=/opt/ros/foxy/share/urdf_tutorial/urdf/06-flexible.urdf
Next, I confirmed that the robot_description
is available as shown below:
ravi@dell:~$ ros2 param list
/joint_state_publisher:
delta
publish_default_efforts
publish_default_positions
publish_default_velocities
rate
source_list
use_mimic_tags
use_sim_time
use_smallest_joint_limits
/robot_state_publisher:
frame_prefix
ignore_timestamp
publish_frequency
robot_description
use_sim_time
use_tf_static
/rviz2:
use_sim_time
Finally, I executed my node which prints URDF model name
ravi@dell:~/ros2_ws$ ros2 run examples_rclcpp_minimal_publisher publisher_member_function
Parsing robot urdf xml string.
[INFO] [1666688084.856405837] [minimal_publisher]: Name:visual
Just for sake of completeness, below is the robot name queried from the terminal:
ravi@dell:~$ ros2 param get /robot_state_publisher robot_description | grep robot
<robot name="visual">
</robot>
Originally posted by ravijoshi with karma: 1744 on 2022-10-25
Comment by Edvard on 2022-10-25:
Thank you so much for you time and help!
Comment by RobotDreams on 2022-10-27:
Is your example code on GitHub somewhere? I want to launch robot state and joint publishers on my robot (not on the Remote Desktop), passing path to the URDF file as a param to the launcher. It seems like your answer is needed for my situation.
Comment by ravijoshi on 2022-10-27:
@RobotDreams: I am out of work now! Give me a day or two, I will upload the complete package to GitHub.
Comment by ravijoshi on 2022-10-28:
@RobotDreams : Here you go: ravijo/minimal_publisher
