I'm trying to install ROS melodic on Fedora 33. I have the following error when compiling package cv_bridge:
error: cannot convert ‘int*’ to ‘cv::UMatData*’ in assignment
264 | m.u = refcountFromPyObject(o);
| int*
In function convert_to_CvMat2 of file module_opencv2.cpp: int convert_to_CvMat2(const PyObject* o, cv::Mat& m) { // to avoid PyArray_Check() to crash even with valid array do_numpy_import();
if(!o || o == Py_None)
if( !m.data )
m.allocator = &g_numpyAllocator;
return true;
if( !PyArray_Check(o) )
failmsg("Not a numpy array");
return false;
// NPY_LONG (64 bit) is converted to CV_32S (32 bit)
int typenum = PyArray_TYPE((PyArrayObject*) o);
int type = typenum == NPY_UBYTE ? CV_8U : typenum == NPY_BYTE ? CV_8S :
typenum == NPY_USHORT ? CV_16U : typenum == NPY_SHORT ? CV_16S :
typenum == NPY_INT || typenum == NPY_LONG ? CV_32S :
typenum == NPY_FLOAT ? CV_32F :
typenum == NPY_DOUBLE ? CV_64F : -1;
if( type < 0 )
failmsg("data type = %d is not supported", typenum);
return false;
int ndims = PyArray_NDIM((PyArrayObject*) o);
if(ndims >= CV_MAX_DIM)
failmsg("dimensionality (=%d) is too high", ndims);
return false;
int size[CV_MAX_DIM+1];
size_t step[CV_MAX_DIM+1], elemsize = CV_ELEM_SIZE1(type);
const npy_intp* _sizes = PyArray_DIMS((PyArrayObject*) o);
const npy_intp* _strides = PyArray_STRIDES((PyArrayObject*) o);
bool transposed = false;
for(int i = 0; i < ndims; i++)
size[i] = (int)_sizes[i];
step[i] = (size_t)_strides[i];
if( ndims == 0 || step[ndims-1] > elemsize ) {
size[ndims] = 1;
step[ndims] = elemsize;
ndims++;
if( ndims >= 2 && step[0] < step[1] )
std::swap(size[0], size[1]);
std::swap(step[0], step[1]);
transposed = true;
if( ndims == 3 && size[2] <= CV_CN_MAX && step[1] == elemsize*size[2] )
ndims--;
type |= CV_MAKETYPE(0, size[2]);
if( ndims > 2 )
failmsg("more than 2 dimensions");
return false;
m = cv::Mat(ndims, size, type, PyArray_DATA((PyArrayObject*) o), step);
if( m.data )
m.addref(); // protect the original numpy array from deallocation
// (since Mat destructor will decrement the reference counter)
if( transposed )
cv::Mat tmp;
tmp.allocator = &g_numpyAllocator;
transpose(m, tmp);
m = tmp;
return true;
Any help is more than welcomed, if more info is needed let me know.
Originally posted by 0novanta on ROS Answers with karma: 18 on 2021-11-09
Comment by osilva on 2021-11-09:
Please take a look at this thread: https://github.com/iterait/hipipe/issues/22
Hope it helps.
Comment by 0novanta on 2021-11-10:
I have found that post while looking for a solution, unfortunately it didn't work for me.
Luckily I was able to find another solution that made me able to compile cv_bridge package, I'll post it as an answer.
