So I made my own robot, and I wanted to use nav2 to control it. I have copied the turtlebot3 files and changed them to work with my robot. Everything works, I can even give it commands via rviz. However, the costmap doesn't work. I have tried everything and yet can't seem to get it working. All I changed was the world that was used by gazebo, the robot itself and I changed the map to my map and made small changes to the yaml file
This is the yaml file that I use:
amcl:
ros__parameters:
use_sim_time: True
alpha1: 0.2
alpha2: 0.2
alpha3: 0.2
alpha4: 0.2
alpha5: 0.2
base_frame_id: "base_footprint"
beam_skip_distance: 0.5
beam_skip_error_threshold: 0.9
beam_skip_threshold: 0.3
do_beamskip: false
global_frame_id: "map"
lambda_short: 0.1
laser_likelihood_max_dist: 2.0
laser_max_range: 100.0
laser_min_range: -1.0
laser_model_type: "likelihood_field"
max_beams: 60
max_particles: 2000
min_particles: 500
odom_frame_id: "odom"
pf_err: 0.05
pf_z: 0.99
recovery_alpha_fast: 0.0
recovery_alpha_slow: 0.0
resample_interval: 1
robot_model_type: "differential"
save_pose_rate: 0.5
sigma_hit: 0.2
tf_broadcast: true
transform_tolerance: 1.0
update_min_a: 0.2
update_min_d: 0.25
z_hit: 0.5
z_max: 0.05
z_rand: 0.5
z_short: 0.05
amcl_map_client:
ros__parameters:
use_sim_time: True
amcl_rclcpp_node:
ros__parameters:
use_sim_time: True
bt_navigator:
ros__parameters:
use_sim_time: True
bt_xml_filename: "navigate_w_replanning_and_recovery.xml"
plugin_lib_names:
- nav2_compute_path_to_pose_action_bt_node
- nav2_follow_path_action_bt_node
- nav2_back_up_action_bt_node
- nav2_spin_action_bt_node
- nav2_wait_action_bt_node
- nav2_clear_costmap_service_bt_node
- nav2_is_stuck_condition_bt_node
- nav2_goal_reached_condition_bt_node
- nav2_initial_pose_received_condition_bt_node
- nav2_reinitialize_global_localization_service_bt_node
- nav2_rate_controller_bt_node
- nav2_recovery_node_bt_node
- nav2_pipeline_sequence_bt_node
- nav2_round_robin_node_bt_node
bt_navigator_rclcpp_node:
ros__parameters:
use_sim_time: True
controller_server:
ros__parameters:
use_sim_time: True
debug_trajectory_details: True
min_vel_x: 0.0
min_vel_y: 0.0
max_vel_x: 0.26
max_vel_y: 0.0
max_vel_theta: 1.0
min_speed_xy: 0.0
max_speed_xy: 0.26
min_speed_theta: 0.0
min_x_velocity_threshold: 0.001
# Add high threshold velocity for turtlebot 3 issue.
# https://github.com/ROBOTIS-GIT/turtlebot3_simulations/issues/75
min_y_velocity_threshold: 0.5
min_theta_velocity_threshold: 0.001
acc_lim_x: 2.5
acc_lim_y: 0.0
acc_lim_theta: 3.2
decel_lim_x: -2.5
decel_lim_y: 0.0
decel_lim_theta: -3.2
vx_samples: 20
vy_samples: 5
vtheta_samples: 20
sim_time: 1.7
linear_granularity: 0.05
xy_goal_tolerance: 0.25
transform_tolerance: 0.2
critics: ["RotateToGoal", "Oscillation", "BaseObstacle", "GoalAlign", "PathAlign", "PathDist", "GoalDist"]
BaseObstacle.scale: 0.02
PathAlign.scale: 0.0
GoalAlign.scale: 0.0
PathDist.scale: 32.0
GoalDist.scale: 24.0
RotateToGoal.scale: 32.0
controller_server_rclcpp_node:
ros__parameters:
use_sim_time: True
local_costmap:
local_costmap:
ros__parameters:
use_sim_time: True
global_frame: odom
plugin_names: ["obstacle_layer", "inflation_layer"]
plugin_types: ["nav2_costmap_2d::ObstacleLayer", "nav2_costmap_2d::InflationLayer"]
rolling_window: true
width: 3
height: 3
resolution: 0.05
footprint_padding: 0.02
footprint: "[[0.7, 0.375], [0.7, -0.375], [-0.2, -0.375], [-0.2, 0.375]]"
inflation_layer:
cost_scaling_factor: 3.0
obstacle_layer:
enabled: True
observation_sources: scan1 scan2
scan1:
topic: /scan
max_obstacle_height: 2.0
clearing: True
marking: True
data_type: "LaserScan"
scan2:
topic: /scan2
clearing: True
marking: True
static_layer:
map_subscribe_transient_local: True
always_send_full_costmap: True
local_costmap_client:
ros__parameters:
use_sim_time: True
local_costmap_rclcpp_node:
ros__parameters:
use_sim_time: True
global_costmap:
global_costmap:
ros__parameters:
use_sim_time: True
plugin_names: ["static_layer", "obstacle_layer", "inflation_layer"]
plugin_types: ["nav2_costmap_2d::StaticLayer", "nav2_costmap_2d::ObstacleLayer", "nav2_costmap_2d::InflationLayer"]
obstacle_layer:
enabled: True
scan1:
topic: /scan
clearing: True
marking: True
scan2:
topic: /scan2
clearing: True
marking: True
static_layer:
global_costmap_client:
ros__parameters:
use_sim_time: True
global_costmap_rclcpp_node:
ros__parameters:
use_sim_time: True
map_server:
ros__parameters:
use_sim_time: True
yaml_filename: "../map/custom_map.yaml"
planner_server:
ros__parameters:
use_sim_time: True
tolerance: 0.0
use_astar: false
planner_server_rclcpp_node:
ros__parameters:
use_sim_time: True
robot_state_publisher:
ros__parameters:
use_sim_time: True
I can even see the updated footprint that I created, but the costmap itself refuses to load for some reason. Has anyone had this problem before, and knows how to solve it?
Edit to add: as you can see in rviz, my robot is able to navigate. However the global and local costmaps both give a warning stating no map has been received.
I would expect a costmap to be made and have the overlay as I have when I run the turtlebot example.
I am using navigation2 with the eloquent-devel branch, with the latest changes (the June 30th update)
2nd edit: I checked my map server, which states the following:
[INFO] [map_server]: Loading yaml file: /home/user/eloquent_ws/install/nena_navigation2/share/nena_navigation2/params/custom_map.yaml
[INFO] [map_server]: Loading image_file: /home/user/eloquent_ws/install/nena_navigation2/share/nena_navigation2/params/custom_map.pgm
My controller server also says that it's creating the costmap and my planner server states this:
[INFO] [global_costmap.global_costmap]: StaticLayer: Resizing costmap to 414 X 621 at 0.050000 m/pix
Which is the size of my map according to the custom_map.pgm
My planner_server does however also show me this message:
[INFO] [global_costmap.global_costmap_rclcpp_node]: Message Filter dropping message: frame 'lidar1' at time 10.968 for reason 'Unknown'
[INFO] [global_costmap.global_costmap_rclcpp_node]: Message Filter dropping message: frame 'lidar2' at time 10.969 for reason 'Unknown'
[INFO] [global_costmap.global_costmap_rclcpp_node]: Message Filter dropping message: frame 'lidar2' at time 19.076 for reason 'Unknown'
[INFO] [global_costmap.global_costmap_rclcpp_node]: Message Filter dropping message: frame 'lidar1' at time 19.076 for reason 'Unknown'
With about 250 lines in between, with only the time changing. But it does stop after that last message, even though I ran the navigation for longer, and from what I could find online it was just something that hadn't been fixed yet, it wasn't anything bad, so I don't really know
Originally posted by Joe28965 on ROS Answers with karma: 1124 on 2020-09-01
Comment by lukicdarkoo on 2020-09-01:
Which ROS distribution do you use? If it is old, it may be related to this PR:
https://github.com/ros2/rviz/pull/375
Comment by Joe28965 on 2020-09-01:
I'm using Eloquent, so I don't think it's related, but thank you for taking the time to answer regardless!
Comment by Phgo on 2020-09-02:
I am actually not sure what exactly is not working in your case. Could you be a little more specific about that?
There has been a change in the plugin interface ([see here](interface https://github.com/ros-planning/navigation2/commit/f3b7be2397f585c53d4940b0fc516d8fe4738670#diff-654f280b3f7a18a77bdf3f828c8538f1)). Which version of navigation2 are you using? From what i can see, your yaml file still uses the old interface.
Comment by Joe28965 on 2020-09-02:
First, let me say thank you for taking the time to help me.
Second, I have updated the question to hopefully explain my issue better.
I am using the eloquent-devel branch of navigation2, with its latest changes.
I have used the turtlebot yaml file in the eloquent-devel branch to make my yaml file, so I'm not sure if I'm using the old interface to be honest (and your link doesn't work for me, for some reason)
Comment by Phgo on 2020-09-03:
Looks like the new plugin interface does not effect the eloquent branch. Anyway, sorry for the broken link. For the sake of completeness: https://github.com/ros-planning/navigation2/blob/foxy-devel/doc/parameters/param_list.md#node-costmap_2d_ros
Are you sure, that the map file ./map/custom_map.yaml
exists and is published correctly (especially with matching QoS)? Are there any relevant Log messages from the map server/ controller server?
Comment by Joe28965 on 2020-09-03:
I updated my question again, I hope I answered your questions.
