I’m trying to simply get a ROS2 workspace going with the demo nodes built. However, following these instructions for making a workspace, when i get to the colcon build --symlink-install step, it needs to build 271 packages. This is a fresh workspace.
This includes packages such as fastrtps, rviz_ogre_vender, ament_cmake_pep8, and many many more. This takes a LARGE amount of time on the Pi3. My main goal was just to have the demo nodes working.
Why are there so many packages being built, do these need to be built every time I make a new workspace, and is there a way to only build new packages if all of these need to be done in the future?
I’m an hour into this build and it isn’t even half way done.
Originally posted by cwillia109 on ROS Answers with karma: 49 on 2020-05-22
Because there are that many packages in the workspace.
It looks like the instructions linked are to build the core of ROS Dashing plus more from source, which is a lot of packages. Is that intended? If ROS Dashing is already installed then put only the packages you want to build (only the demo nodes you mentioned) in the workspace.
No. The workspace only needs to have the packages you want to work on. Put only the packages you want to build in the src folder of the workspace, then source /opt/ros/dashing/setup.bash before running colcon build.
Colcon has a few options for picking which packages to build. Run colcon build -h and look for options starting with --packages-
--packages-ignore [PKG_NAME [PKG_NAME ...]]
--packages-ignore-regex [PATTERN [PATTERN ...]]
--packages-up-to [PKG_NAME [PKG_NAME ...]]
--packages-above [PKG_NAME [PKG_NAME ...]]
--packages-above-depth DEPTH [PKG_NAME ...]
--packages-select-by-dep [DEP_NAME [DEP_NAME ...]]
--packages-skip-by-dep [DEP_NAME [DEP_NAME ...]]
--packages-skip-up-to [PKG_NAME [PKG_NAME ...]]
--packages-select-build-failed
--packages-skip-build-finished
--packages-select-test-failures
--packages-skip-test-passed
--packages-select [PKG_NAME [PKG_NAME ...]]
--packages-skip [PKG_NAME [PKG_NAME ...]]
--packages-select-regex [PATTERN [PATTERN ...]]
--packages-skip-regex [PATTERN [PATTERN ...]]
--packages-start PKG_NAME
--packages-end PKG_NAME
You might be interested in the colcon build documentation.
Originally posted by sloretz with karma: 3061 on 2020-05-22
Comment by cwillia109 on 2020-05-22:
I feel dumb now. Started from scratch and everything is working fine.
