Hi, I have a nodelet that publishes a few topics and another nodelet that subscribes the topics and republishes a custom topic with all the synchronized messages.
If I start the two nodelets in two separate nodelet managers everything works as expected, if I use a single nodelet manager that loads both the nodelets the subscriber receives only a few messages than stops.
I'm using the ApproximateTime policy.
The topics run at different frequencies: 400Hz, 15Hz and 50Hz.
Any idea about the cause of the problem and about how to debug to find a possible cause?
Thank you Walter
Originally posted by Myzhar on ROS Answers with karma: 541 on 2020-03-13
Comment by gvdhoorn on 2020-03-16:
Please do not close questions when you've actually anwered them.
Just click the checkmark to the left of the answer. That will provide a much clearer indication the question has been answered.
I found the solution to the problem.
I was wrongly not creating a new message before each publishing.
In my particular case I had an IMU message to be synchronized with camera images and I was creating the message once in the OnInit function. Instead we must create each single shared pointer message just before publishing it: sensor_msgs::ImuPtr imuMsg(new sensor_msgs::Imu);
Originally posted by Myzhar with karma: 541 on 2020-03-16
