Following the tutorial of ros1_bridge
I can bridge the ros1 topics to ros2 and worked very well.
And I want to use this feature to communicate between multi-robots through DDS
But there is a problem with bridging big_data like image_raw when I use --bridge-all-topics
It will cause the network traffic jams
Is it possible to bridge specific topic or just except some topics that I don't want it bridged to ros2?
Thank you
Originally posted by NEET on ROS Answers with karma: 13 on 2019-08-01
Comment by Dirk Thomas on 2019-08-01:
Which bridge executable are you currently using? There are different ones for different use cases: dynamic_bridge
, parameter_bridge
, static_bridge
Comment by NEET on 2019-08-01:
@Dirk Thomas I use dynamic_bridge. I have no idea about other methods...
