Hello,
I am very new to ROS and I have just manged to integrate the ROS libraries into my QT IDE.
I am building a fairly complex application, however the ROS subscriber example I am attempting to implement fairly simple.
If I implement my code this way (per the examples), I get subscriber callbacks as expected:
void MainWindow::rtsp1Callback(const sensor_msgs::Image::ConstPtr& msg)
qDebug() << "rtsp1 Image has data";
With this initializer:
void MainWindow::on_ROSSubscribeButton_clicked()
ros::init(m_argc, m_argv, "camera_check");
ros::NodeHandle n1;
ros::Subscriber sub1 = n1.subscribe("/rtsp_1/image_raw", 100, &MainWindow::rtsp1Callback, this);
ros::spin();
But of course, this is an undesirable design, as ros::spin();
then blocks the rest of my program.
So I execute a timer to call ros::spinOnce();
on demand:
Callback unchanged:
Initializer with timer:
ros::NodeHandle n1;
CameraCheckTimer.start(100); //calls ros::spinOnce() every 1000ms;
And this spin call (on timer execution):
void MainWindow::checkCameras()
ros::spinOnce();
qDebug() << "Spin!";
However I do not get any callbacks.
I also tested calling ros::spin() - which was working in my initial example, by calling a singleShot timer. When I do this, my program blocks as expected, however I do not get any callbacks.
This makes me suspect that ros::spin() and ros::spinOnce() are somehow getting an implicit pointer to the GlobalCallbackQueue from the ros::init() function. Is this the case?
If so, what is the data type of ros::GlobalCallbackQueue (so that I can pass a global pointer to it into my timer loop)?
Or, if you have an example of how to simply fix my problem, I will accept that as well!
Originally posted by riot on ROS Answers with karma: 28 on 2019-07-12
