You can either declare them one at a time, e.g.:
int base_id = node->declare_parameter("tag_lists.base.id").as_int();
double base_size = node->declare_parameter("tag_lists.base.size").as_double();
int object_id = node->declare_parameter("tag_lists.object.id").as_int();
double object_size = node->declare_parameter("tag_lists.object.size").as_double();
Or you can declare more than one at a time (http://docs.ros2.org/dashing/api/rclcpp/classrclcpp_1_1Node.html#a70012f2efbed147a2710343856acace5), so long as they have the same type (not the case in your example), e.g. for this yaml:
robot1:
laser_topic: /scan
camera_topic: /left_camera
tf_frame: robot1
You could declare them like this:
std::vector<std::string> params = node->declare_parameters("robot1", {
{"laser_topic", "default_scan"},
{"camera_topic", "default_image"},
{"tf_frame", "default_world"},
But, if you don't know the names ahead of time, then you can have the node automatically declare all of the parameters in the yaml file (we consider them to be overrides, so we refer to those as "parameter overrides") with this option:
http://docs.ros2.org/dashing/api/rclcpp/classrclcpp_1_1NodeOptions.html#a094ceb7af7c9b358ec007a4b8e14d40d
Ideally, we'd have a version of declare_parameters
which didn't require a default value and that could take/return ParameterValue
objects so that you could use it with a heterogeneous list of parameters (mixing int and float in your case). But we don't have that right now. But you could create a helper function in the meantime, our declare_parameters is quite simple:
https://github.com/ros2/rclcpp/blob/2bee266adf5b35c3c80b1e5b7224c0e3bdd8f2a8/rclcpp/include/rclcpp/node_impl.hpp#L262-L302
EDIT1:
Also, if you want you can get the parameter overrides (combined from the yaml files and the programmatic parameter overrides from the NodeOptions
) via the NodeParameters
API. You can get it from the node with get_node_parameters_interface() and then get the overrides with get_parameter_overrides(), e.g.:
auto node_parameters_iface = node->get_node_parameters_interface();
std::map<std::string, rclcpp::ParameterValue> & parameter_overrides =
node_parameters_iface->get_parameter_overrides();
And then you could iterate of that how ever you like.
Originally posted by William with karma: 17335 on 2019-06-17
Comment by Christian Rauch on 2019-06-20:
Yes, one problem is that base
and object
are not known in advance.
I tried to circumvent this with a structure like:
tag_lists:
- frame: base
- frame: object
But the parser expects that all values are of the same type:
Failed to parse yaml params file '[configuration].yaml': Sequence should be of same type. Value type 'integer' do not belong at line_num [line with "id: 9"], at /tmp/binarydeb/ros-dashing-rcl-yaml-param-parser-0.7.5/src/parser.c:931
