I can help clear up the questions about ROS MultiArray messages, but first as has been suggested I can show you how to define a custom message specifically for your ground penetrating RADAR sensor. The language of ROS message files is described here, as well as a description how to update your CMakeLists.txt file so that they will be built correctly.
The idea here is to define a message type which represents a sample and another message type which contains an array of these samples along with any additional data. Keeping in mind that ROS uses SI units by convention. First the sample message:
GPRSample.msg
# Ground Penetrating Radar Sample Message
float32 delay_secs
float amplitude
I'm not sure if your sensor produces an amplitude metric in units at all or if you get an un-quantified integer value. This could be an example where we don't use SI units in ROS, the laser_scan message for example uses a float32 of no unit to describe reflected pulse intensity because none of the LIDAR manufacturers I know of publish the units of the intensity data their sensors produce.
GPREcho.msg
# Ground Penetrating Radar Echo Message
Header header
# power emitted by Radar (just a guess, don't know if this is relevant)
float emitter_power_watts
# variable length array of gpr samples
GPRSample[] samples
When these two message are built you can then use in python as below
from <your_package_name>.msg import GPRSample
from <your_package_name>.msg import GPREcho
def make_message():
gpr_msg = GPREcho()
for i in range(10):
gpr_sample = GPRSample()
gpr_sample.delay_secs = i / 1000000000.0
gpr_sample.amplitude = 10 * sin(i)
gpr_msg.samples += [gpr_sample]
gpr_msg.emitter_power_watts = 10
gpr_msg.header.frame_id = "sensor_frame"
gpr_msg.header.stamp = rospy.get_rostime()
return gpr_msg
Using custom messages in this way means that there is useful meta-data along with your raw values, so that other developers and parts of the ROS system can know exactly what the data is. This is not possible with a simple matrix of values, the solution above is how we would recommend you solve this problem. However I will also address your questions about ROS MultiArrays because you're not the first and won't be the last person to be confused by them.
All of the MultiArray messages specify a 1 dimensional flat array which contains the actual data within the array. As well as this it also defines the structure of an n dimensional array which maps onto this 1 dimensional data, this allows it to represent a 3D cube of data, a 2D matrix, a 4D tensor, anything you want. However this power also makes it quite complicated to use in simple cases.
Taking your use case you want to define a 2D matrix of size 2x4096, and we'll use row-major ordering. Create a FloatMultiArray message and put the data into first as a flat array of 8192 elements.
msg = Float32MultiArray()
msg.data = my_data.reshape([8196])
Now we need to define the layout so that ROS knows this data is actually a 2x4096 matrix:
# This is almost always zero there is no empty padding at the start of your data
msg.layout.data_offset = 0
# create two dimensions in the dim array
msg.layout.dim = [MultiArrayDimension(), MultiArrayDimension()]
# dim[0] is the vertical dimension of your matrix
msg.layout.dim[0].label = "channels"
msg.layout.dim[0].size = 2
msg.layout.dim[0].stride = 8196
# dim[1] is the horizontal dimension of your matrix
msg.layout.dim[1].label = "samples"
msg.layout.dim[1].size = 4096
msg.layout.dim[1].stride = 4096
The stride in these dimensions refers to how many samples along the next higher dimension is. So in the case of the samples, there is a stride of 4096 to the next sample. In the case of dimension zero there is no higher dimension so the stride is the overall size of the message data.
I hope this clears some of this up for you. I do recommend defining custom messages though, it's a bit of a pain at first but when you get used to it you'll never look back.
Originally posted by PeteBlackerThe3rd with karma: 9529 on 2019-06-12
Post score: 7
Comment by gvdhoorn on 2019-06-13:\
Just some rationale for this comment: as I wrote in #q325416, using std_msgs
for this would allow any subscriber of Float32MultiArray
messages to subscribe to your GPR publisher. Even if my node expects image data encoded in a Float32MultiArray
, it would succeed in subscribing. It would completely misinterpret the data though, as it expect 2d image data, not GPR return samples.
Unfortunately, when using std_msgs
directly, there is no way for your node to convey the fact that it is publishing GPR data -- other than extensively documenting it. But people don't read documentation. They start nodes, .launch
files, etc. Until things stop working.
By creating a custom, semantically meaningful message, such as the one @PeteBlackerThe3rd shows in his answer, it would be impossible for my image processing node to subscribe to your GPR topic, ..
.. simply because the types would be incompatible.
Additionally, the custom message perfectly captures the semantics (ie: meaning) of the data: each field has an appropriate name and that name almost explains what data it carries. This should reduce the amount of guessing (or reading of documentation) on the part of the consumer signficantly and greatly aids in making sure producer and consumer both understand the data they are exchanging.
People that start out with ROS typically go to std_msgs
as they feel they are "exchanging integers, strings and arrays". That is understandable, but I hope it's clearer now that you're really exchanging data with meaning, and that without capturing those semantics in your messages, you may as well send over everything as raw byte arrays.
One final comment: even though I seem to be suggesting to create custom messages for everything (as they better capture the semantics of the data), there is one thing you should always do: always prefer to use "official" messages for your data first.
So instead of creating a custom message to carry the distances measured by a ultrasonic sensor, use sensor_msgs/Range
. Instead of creating a message that carries a single float64[]
for the joint states of a robot, use sensor_msgs/JointState
. And so on.
Using such messages will greatly increase the chance that you'll be able to reuse software from others, and tools such as RViz for instance will work with messages from sensor_msgs
, but not with your own custom ones (unless you write a plugin).
Comment by dual-swordsman on 2019-06-13:
@PeteBlackerThe3rd @gvdhoorn thank you so much for detailed explanation for my questions. Everything is clearing up now. I really appreciate both of your help. I will take the suggestion of using custom message as it is much more suitable and simpler in my project. :D
How do I say that this question is already answered?
Comment by PeteBlackerThe3rd on 2019-06-13:
Great, glad we could help. If you click the tick mark at the top left of this answer it will mark it as accepted.
Comment by dwd394 on 2022-08-01:
Thank you! :)
