I am trying to use the inverse kinematics (IK) solver in ur_driver for my UR5 robot. My goal is to move the robot to a target joint position given a set of robot TCP pose/end-effector pose. However, there is always a small error (about 1mm) in each x/y/z axis after positioning. So I did this quick test for the ur_driver as follows.
1 First, position robot using movegroup.
map<string, double> jointPose;
jointPos["shoulder_pan_joint"] = -0.9217;
jointPos["shoulder_lift_joint"] = -1.5935;
jointPos["elbow_joint"] = 2.236;
jointPos["wrist_1_joint"] = -0.4291;
jointPos["wrist_2_joint"] = 0.2916;
jointPos["wrist_3_joint"] = 0.7746;
move_group.setPoseTarget(another_pose);
move_group.move();
2. Second, record robot tool0 pose as shown in RViz, result as follows.
[position(m),orientation(quaternion)] = [0.33561, -0.13135, 0.1815, 0.64684, 0.33476, 0.68078, 0.077926].
3. Third, position robot with URScript movej() command, record robot tool pose as shown on the polyscope.
[position(m),orientation(rxryrz)] = [0.33667,-0.13125,0.18217,0.7471,-1.4515,-0.1768]
As I can see, there is a slight position difference in each x/y/z direction. So my assumption is the IK solution given by ur_driver is not precise.
I have compared the DH parameters in the driver to that given by [1]. They seem to be the same.
Does anyone know how to compute the accurate IK solution for UR robot? I appreciate any help and insight that could potentially solve the problem.
[1] https://www.universal-robots.com/how-tos-and-faqs/faq/ur-faq/parameters-for-calculations-of-kinematics-and-dynamics-45257/
Originally posted by myf123asd on ROS Answers with karma: 3 on 2019-06-06
ur_driver does not contain any functionality related to IK or FK.
FK is performed by robot_state_publisher based on the urdf, or the integrated version of that in MoveIt.
IK is performed by whatever kinematics solver you have configured. That could be ur_kinematics, trac_ik, KDL or something else.
The urdf is most certainly not completely correct for your robot. That would be one source of positional error. That is being addressed in ros-industrial/universal_robot#414.
Secondly: both URScript, MoveIt and the driver use different tolerances for when a motion is completed. It could well be that this also contributes here.
Finally, the differences you show appear to be in the micrometers range (ROS uses metres for distances):
        X        Y        Z
moveit: 0.33561 -0.13135  0.1815
movej:  0.33667 -0.13125  0.18217
       -0.00106  0.0001  -0.00067
The repeatability of a UR5 is specced as +-0.1mm or 0.001m (datasheet). Taking that into account the differences don't seem to be so egregious.
Originally posted by gvdhoorn with karma: 86574 on 2019-06-06
Comment by myf123asd on 2019-06-11:
Thank you for pointing out the discussion. The problem was that I did not consider the manufacturer's calibration. Without the calibration data, using moveIt and universal_robot package to navigate the robot will result in at least 2mm off from the target TCP pose. The positional error I mentioned was in meter actually.
Comment by gvdhoorn on 2019-06-11:\
yes, as I assumed. But 1e-4 would still fall in the micrometre range.
