I have a service node server that handles a simple request by a client. The client sends an id (as a string), which the server then should read out. I am using rospy.
If I print the message in the server, it says "request: 1". I want to only extract the "1". How do I do that?
Rephrasing a bit: what "member" of the message do I have to call to get the raw data? Something like message.data
Here's the handler:
def handle_cac(request):
# receive goal id, return goal information
print("Received this message: ")
print request.data # this does not work! I'd like to just get the raw id, e.g. "1"
for goals in root.getchildren():
for goal in goals.getchildren():
print goal.tag
print goal.attrib
if goal.attrib.text == request.data:
print "Found goal: " + goal.name
# print((root.findall("goals"))[0][0].attribute)
return "nothing"
And here's the client:
def cac_client(request_message):
print "Running request"
rospy.wait_for_service('CAC')
try:
GetGoal = rospy.ServiceProxy('CAC', cac)
resp1 = GetGoal(request_message)
print resp1
return resp1
except rospy.ServiceException, e:
print "Service call failed: %s" %e
if __name__ == "__main__":
cac_client("1")
Originally posted by mneumann on ROS Answers with karma: 13 on 2018-09-18
Comment by mgruhler on 2018-09-18:
what type of service are you using? What are you writing in your client? Could it be that you are actually writing request: 1
in it?
Comment by mneumann on 2018-09-18:
I added the client's code to the question.
What service type is that? I see cac
, but I don't know what this is supposed to be. You can actually have a look at the cac
definition yourself. This is the data member...
E.g. the AddTwoInts.srv
of the beginner_tutorials
has the members a
and b
Sorry, I was not sure what you meant. This is what it looks like: string request \--- string response
. Ignore the \
, didn't know how to escape the -
in this comment. Also, the type seems to be "cacRequest", which is normal for services, right?
yes, basically from the srv definition you posted, two "messages" are created, which are called cacRequest and cacResponse, in this case...
How do I access the raw string I sent via these messages?
some patience, man ;-D
