As said in the title I am getting thrown the following error: ‘SensorManager’ is not a member of ‘gazebo::sensors’
I am running ROS Kinetic with Gazebo 7 on Ubuntu 16.04
My GCC version is "gcc (Ubuntu 5.4.0-6ubuntu1~16.04.10) 5.4.0 20160609"
Other people who have had this problem have a linking problem in the CMakelists file, but I've gone over it a few times and can't spot the problem. Any help would be appreciated.
The function is in a world plugin -
int getNumberOfWalls()
    //Get  bumpsensor
    gazebo::sensors::SensorManager mgr = sensors::SensorManager::Instance();
Here is my CMakeLists.txt
cmake_minimum_required(VERSION 2.8.7)
project(weaselball_gazebo)
add_compile_options(-std=c++11)
  roscpp
  gazebo_ros
find_package(gazebo REQUIRED)
## Dependencies
include( FindPkgConfig )
if( PKG_CONFIG_FOUND )
  pkg_check_modules( GAZEBO REQUIRED gazebo )
endif()
message (${GAZEBO_LIBRARY_DIRS})
link_directories( ${GAZEBO_LIBRARY_DIRS} )
include_directories( ${GAZEBO_INCLUDE_DIRS} )
#if( PKG_CONFIG_FOUND )
#  pkg_check_modules( RAVELIN ravelin )
#endif()
#include_directories( ${RAVELIN_INCLUDE_DIRS} )
#link_directories( ${RAVELIN_LIBRARY_DIRS} )
include (FindPkgConfig)
if (PKG_CONFIG_FOUND)
  pkg_check_modules(GAZEBO gazebo)
  pkg_check_modules(OGRE OGRE)
  pkg_check_modules(OGRE-Terrain OGRE-Terrain)
endif()
link_directories(${GAZEBO_LIBRARY_DIRS} ${OGRE_LIBRARY_DIRS})
include_directories(${Boost_INCLUDE_DIR} ${catkin_INCLUDE_DIRS} ${GAZEBO_INCLUDE_DIRS} ${OGRE_INCLUDE_DIRS} ${OGRE-Terrain_INCLUDE_DIRS})
    ## Code
    set( LIBS
      ${GAZEBO_LIBRARIES}
  ${RAVELIN_LIBRARIES}
  libRavelin.so
set( HDRS
  include/common.h
  include/math.h
  include/log.h
  include/state.h
  include/virtual_time.h
  include/vicon.h
  include/video.h
  include/movie.h
  include/models.h
  include/weazelball.h
  include/gazebo_log.h
  include/bumpSensor.h
set( SRCS
add_library(configure SHARED plugins/initConditionHandler.cpp)
target_link_libraries(configure ${GAZEBO_LIBRARIES})
add_library(StateRecorder SHARED plugins/stateRecorder.cpp)
target_link_libraries(StateRecorder ${GAZEBO_LIBRARIES} ${CATKIN_LIBRARIES})
#This plugin is still being developed...
#add_library(bumpSensor SHARED src/bumpSensor.cpp)
#target_link_libraries(bumpSensor ${GAZEBO_LIBRARIES})
#target_link_libraries(${PROJECT_NAME} ${catkin_LIBRARIES} ${GAZEBO_LIBRARIES})
add_library( simulation-controller SHARED plugins/simulation_controller.cpp ${HDRS} ${SRCS} )
target_link_libraries( simulation-controller ${LIBS} )
catkin_package(
  DEPENDS
    roscpp
    gazebo_ros
echoing the GAZEBO_LIBRARY_DIRS gave me:
/usr/lib/x86_64-linux-gnu/gazebo-7/plugins/usr/lib/x86_64-linux-gnu/usr/lib/x86_64-linux-gnu/gazebo-7/plugins/usr/lib/x86_64-linux-gnu
and finally my package.xml -
<?xml version="1.0"?>
<package format="2">
  <name>weaselball_gazebo</name>
  <version>0.0.0</version>
  <buildtool_depend>catkin</buildtool_depend>
  <build_depend>roscpp</build_depend>
  <build_export_depend>roscpp</build_export_depend>
  <exec_depend>roscpp</exec_depend>
  <build_depend>gazebo_ros</build_depend>
  <exec_depend>gazebo_ros</exec_depend>
  <build_export_depend>gazebo</build_export_depend>
  <exec_depend>gazebo</exec_depend>
  <!-- The export tag contains other, unspecified, tags -->
  <export>
    <!-- Other tools can request additional information be placed here -->
  <gazebo_ros plugin_path="${prefix}/lib" gazebo_media_path="${prefix}" />
  </export>
</package>
Once again any help would be appreciated.
Originally posted by Cler on ROS Answers with karma: 1 on 2018-08-01
Can you verify that you are including <gazebo-7/gazebo/sensors/SensorManager.hh>? Also try changing your line to gazebo::sensors::SensorManager *mgr = gazebo::sensors::SensorManager::Instance();
Originally posted by stevejp with karma: 929 on 2018-08-01
Comment by Cler on 2018-08-01:
Yep that was it, I feel stupid. Thanks for the help.
