I'm still writing integration test and I'm stuct at asimple exmaple where I want my testcase to publish a message and also subscrib to the same topic
class AdvancedTestSuite(unittest.TestCase):
    def test_joint_states(self):
        rospy.init_node('test_vehicle_controller', anonymous=True)
        joint_state = JointState()
        joint_state.name = ['lift_actor', 'wheel_main_rotation', 'wheel_main_steer']
        joint_state.velocity = (0.02069770811665661, 0.0014280281623658617, 1.1028179833702783e-05)
        joint_state.position = (0.9990335843981955, -0.12971652493225605, -0.0031193465124985664)
        joint_state.effort = (37.26698108917237, 0.0, 0.0)
        rospy.Subscriber('/my_ns/joint_states', JointState, self.callback_state)
        pubA = rospy.Publisher('/my_ns/joint_states', JointState, queue_size=10)
        pubA.publish(joint_state)
    def callback_state(self, state):
        rospy.loginfo("received " + repr(state))
if __name__ == '__main__':
    import rostest
    rostest.rosrun(PKG, 'test_joint_states', AdvancedTestSuite)
but nothing happens the callback is called. I can not even debug what wrong. Any Ideas ?
Originally posted by Westranger on ROS Answers with karma: 165 on 2017-11-14
Comment by gvdhoorn on 2017-11-14:
And just a note: rostest is not subscribing to anything. rostest is just the test driver here in this case. Your code is subscribing.
Suggestion: change the question title to reflect this better.
Comment by Westranger on 2017-11-14:
Thank you for your comment. This shows again that I dont fully understand internal ROS concepts (yet).
No problem. We're all posting here to learn.
It takes some time for subscriptions to be setup (this is a networked middleware, not a local function call). There is probably on the order of a few milliseconds between the creation if your publisher and your subscriber, you then publish(..) and your program exits immediately. Try to add a time.sleep(..) at appropriate places to see whether that is the problem.
Originally posted by gvdhoorn with karma: 86574 on 2017-11-14
I already added a time.sleep(...) without a whole loop after the publish(...) without anything luck. Do I also need to wait before the publish ? It would also bei nice to somehow debug the situation. But rostopic for example complaints thats the ros master is not reachable
Comment by gvdhoorn on 2017-11-14:\
that is probably the most important place to sleep.
If you're not a fan of doing this time-based, and would rather do it state-based (I would), then you could use pubA.get_num_connections() to wait for a connection before publishing.
See rospy.Publisher for the API docs for that.
well this is Python, and your test is basically a Python script, so pdb could perhaps help here.
But as there is a network involved, and most things are asynchronous, debugging could prove difficult.
Comment by Westranger on 2017-11-15:
@gvdhoorn I solved it with a time.sleep(...) before the publish, thanks
Comment by gvdhoorn on 2017-11-15:
Suggestion: use a state-based approach. If for whatever reason the publisher and / or subscriber need more time to initialise (perhaps due to resource contention with other processes on the machine running your tests), you run the risk of the test failing for no good reason.
