Hey Guys,
I'm have a robot arm I'm trying to put into ros. I went through the urdf_tutorial and got a urdf that works with the tutorial launch file. Now, I want to write a node that publishes to /joint_states and uses robot_state_publisher to update the robot. I'd like to display the robot in rviz, and also write a subscriber to /joint_states that moves the actual arm.
The problem I'm having is, when I write my own simple node to publish to /joint_states, rviz gives me errors for all of my joint transforms. (ie "no transform from [first_segment] to [base_link]" and "no transform from [second_segment] to [base_link]", also there's "Fixed Frame: No tf data. Actual error: Fixed Frame [base_link] does not exist"
I've looked at the documentation for robot_state_publisher, read the code for joint_state_publisher and tried manually sending tf's through my node.
I use this command to put in my urdf and launch the code:
roslaunch launch/display.launch model:=urdf/josh-arm.urdf
Here's my urdf, launch file, and python code (sorry I couldn't attach it.. don't have enough karma):
Thanks!
<launch>
<arg name="model" />
<arg name="gui" default="true" />
<arg name="rvizconfig" default="$(find urdf_tutorial)/rviz/urdf.rviz" />
<param name="robot_description" command="$(find xacro)/xacro.py $(arg model)" />
<param name="use_gui" value="$(arg gui)"/>
<node name="updateArm" pkg="me439arm" type="updateArm.py"/>
<node name="robot_state_publisher" pkg="robot_state_publisher" type="state_publisher" />
<node name="rviz" pkg="rviz" type="rviz" args="-d $(arg rvizconfig)" required="true" />
</launch>
The urdf file:
<?xml version="1.0"?>
<robot name="visual">
<material name="blue">
<color rgba="0 0 0.8 1"/>
</material>
<material name="black">
<color rgba="0 0 0 1"/>
</material>
<material name="white">
<color rgba="1 1 1 1"/>
</material>
<link name="base_link">
<visual>
<geometry>
<cylinder length="0.1026" radius="0.025"/>
</geometry>
</visual>
</link>
<link name="base_rotate">
<visual>
<geometry>
<sphere radius="0.025"/>
</geometry>
<origin rpy="0 0 0" xyz="0 0 .1026"/>
<material name="white"/>
</visual>
</link>
<joint name="base_joint" type="revolute">
<axis xyz=" 0 0 1"/>
<parent link="base_link"/>
<origin rpy="0 0 0" xyz="0 0 0"/>
<limit effort="1000.0" lower="-3.14159" upper="3.14159" velocity=".5"/>
<child link="base_rotate"/>
</joint>
<link name="first_segment">
<visual>
<geometry>
<cylinder length="0.1180" radius="0.025"/>
</geometry>
<origin rpy="0 0 0" xyz="-.0310 0 .059"/>
</visual>
</link>
<joint name="first_segment_joint" type="revolute">
<axis rpy="0 1 0" xyz="0 1 0"/>
<origin rpy="0 0 0" xyz="0 0 .1"/>
<parent link="base_rotate"/>
<child link="first_segment"/>
</joint>
<link name="second_segment">
<visual>
<geometry>
<cylinder length="0.02" radius="0.025"/>
</geometry>
<origin rpy="0 0 0" xyz="0 0 .01"/>
</visual>
</link>
<joint name="second_segment_joint" type="revolute">
<origin rpy="0 0 0" xyz="-.0310 0 .1180"/>
<parent link="first_segment"/>
<child link="second_segment"/>
</joint>
<link name="third_segment">
<visual>
<geometry>
<cylinder length=".1335" radius="0.025"/>
</geometry>
<origin rpy="0 0 0" xyz="0 0 0.06675"/>
</visual>
</link>
<joint name="third_segment_joint" type="revolute">
<axis rpy="0 0 1" xyz="0 0 1"/>
<origin rpy="0 -1.570796 0" xyz="0 0 .02"/>
<parent link="second_segment"/>
<child link="third_segment"/>
</joint>
<link name="wrist_segment1">
<visual>
<geometry>
<cylinder length="0.029" radius="0.025"/>
</geometry>
<origin rpy="0 0 0" xyz="0 0 0.0145"/>
</visual>
</link>
<joint name="wrist_segment_joint1" type="revolute">
<axis rpy="0 0 1" xyz="0 1 0"/>
<origin rpy="0 0 0" xyz="0 0 .1335"/>
<parent link="third_segment"/>
<child link="wrist_segment1"/>
</joint>
<link name="wrist_segment2">
<visual>
<geometry>
<cylinder length="0.001" radius="0.025"/>
</geometry>
</visual>
</link>
<joint name="wrist_segment_joint2" type="revolute">
<origin rpy="0 0 0" xyz="0 0 .025"/>
<parent link="wrist_segment1"/>
<child link="wrist_segment2"/>
</joint>
</robot>
The Python file (based on the publisher tutorial):
#!/usr/bin/env python
# license removed for brevity
import rospy
from sensor_msgs.msg import JointState
import tf
br = tf.TransformBroadcaster();
def get_param(name, value=None):
private = "~%s" % name
if rospy.has_param(private):
return rospy.get_param(private)
elif rospy.has_param(name):
return rospy.get_param(name)
else:
return value
def talker():
pub = rospy.Publisher('joint_states', JointState, queue_size=10)
rospy.init_node('updateArm', anonymous=True)
rate = rospy.Rate(10) # 10hz
msg = JointState()
msg.name = ['base_joint', 'first_segment_joint', 'second_segment_joint', 'third_segment_joint', 'wrist_segment_joint1', 'wrist_segment_joint2'];
msg.position = [0,0,0,0,0,0]
source_list = get_param("source_list", [])
rospy.loginfo(str(source_list))
msg.header.stamp = rospy.Time.now();
pub.publish(msg)
rate.sleep()
if __name__ == '__main__':
try:
talker()
except rospy.ROSInterruptException:
pass
Originally posted by jtabor on ROS Answers with karma: 3 on 2017-11-08
Comment by jayess on 2017-11-09:
Don't worry about not being able to your code as a file. It's actually better to include the code in the question as you have done here.
