I was planning to use Header seq value to verify that communication in my system of ROS-nodes (using ROS Indigo) is synchronized, however, I discovered a couple issues with that value. If that's a bug, I guess I can submit it to the ROS issue tracker.
- The value of seq in the first message published with a rospy node is 1, whereas the value of seq in the same case with roscpp node is 0 (see examples below). That looks somewhat inconsistent. Is that an expected behavior or a bug?
- In rospy, msg.header.seq is updated every time the message is published. In roscpp, in the published data the value is incremented as well, but the value in the message object itself doesn't seem to be updated (always 0). How to actually read that value?
Python example
First, let's take a look at a slightly modified talker example from the tutorials:
#!/usr/bin/env python
import rospy
from geometry_msgs.msg import PoseStamped
def talker():
pub = rospy.Publisher('chatter', PoseStamped, queue_size=1000)
rospy.init_node('talker', anonymous=True)
rospy.sleep(10) # just to ensure we don't miss any messages with rostopic echo
rate = rospy.Rate(1)
msg = PoseStamped()
pub.publish(msg)
rospy.loginfo("seq=%d" % msg.header.seq)
rate.sleep()
if __name__ == '__main__':
try:
talker()
except rospy.ROSInterruptException:
pass
The output of the node is:
$ rosrun my_pkg chatter.py
[INFO] [WallTime: 1477087924.109463] seq=1
[INFO] [WallTime: 1477087925.110565] seq=2
[INFO] [WallTime: 1477087926.110574] seq=3
And the output of rostopic echo /chatter/header/seq is:
$ rostopic echo /chatter/header/seq
C++ example
Now a seemingly equivalent c++ node:
#include "ros/ros.h"
#include "geometry_msgs/PoseStamped.h"
int main(int argc, char **argv) {
ros::init(argc, argv, "talker");
ros::NodeHandle n;
ros::Publisher chatter_pub = n.advertise<geometry_msgs::PoseStamped>("chatter", 1000);
ros::Rate loop_rate(1);
ros::Duration(5).sleep();
geometry_msgs::PoseStamped msg;
while (ros::ok()) {
chatter_pub.publish(msg);
ros::spinOnce();
ROS_INFO("seq=%d", msg.header.seq);
loop_rate.sleep();
return 0;
[ INFO] [1477088294.353026135]: seq=0
[ INFO] [1477088294.353167359]: seq=0
[ INFO] [1477088295.353267882]: seq=0
Originally posted by sd1074 on ROS Answers with karma: 21 on 2016-10-21
Comment by sd1074 on 2016-10-29:
I submitted this issue to ros_comm tracker: https://github.com/ros/ros_comm/issues/921
