Hi,
I want to get the Position (x, y) and the orientation from my robot. The position should be relative to the map TF. Therefore I used a TransformListener:
tf::StampedTransform transform_bot;
tf::TransformListener listener;
listener.lookupTransform("/map", "/base_footprint", ros::Time(0), transform_bot);
bot_x = transform_bot.getOrigin().x();
bot_y = transform_bot.getOrigin().y();
double roll, pitch, yaw;
transform_bot.getBasis().getRPY(roll, pitch, yaw);
bot_dir = yaw * 180.0 / PI;
ROS_INFO("Bot X: %f", bot_x);
ROS_INFO("Bot Y: %f", bot_y);
ROS_INFO("Bot Z: %f", bot_dir);
So far I was not able to get good result with this solution...
Do you have any ideas, how to solve the problem?
Thank you, Sebastian
Originally posted by SeanAda on ROS Answers with karma: 3 on 2016-08-10
