I have a bit of code that outputs data when the core dies. This works fine in all situations, except when the user uses 'rosnode kill -a'. The PR2 runs this command when stopping the robot, so it's a larger issue with specific robots than with ROS itself.
I believe this particular command is running a SIGKILL on all ROS nodes. These cannot be caught. Is there some other signal ROS sends out right before it dies that I can take advantage of?
Originally posted by curranw on ROS Answers with karma: 211 on 2016-07-29
