Hi,
I just started with ros and don't have much experience. I already installed the the nav2d package.
Like in the tutorial described, I started the command rosservice call /StartMapping 3 and the robot drives 1 meter forward and makes a 180 turn. I don't know if that is correct. Then I start rosservice call /StartExploration 2 and then the following error is given:
Failed to compute odometry pose, skipping scan ("base_laser_link" passed to lookupTransform argument source_frame does not exist. )
[ERROR] [1468626044.630942697]: You must specify at least three points for the robot footprint, reverting to previous footprint.
[ERROR] [1468626142.281016628]: Is the robot out of the map?
[ERROR] [1468626142.281070197]: Exploration failed, could not get ent position.
In my tf tree I can't find the base_laser_link.
You can find my rqt_graph here.
I start my TurtleBot with minimal.launch and I also start my 3D sensor. After that, I start the following launch file. My tutorial3 launch file is:
<param name="use_sim_time" value="false" />
<rosparam file="$(find nav2d_tutorials)/param/ros.yaml"/>
<!-- Start the Operator to control the simulated robot -->
<node name="Operator" pkg="nav2d_operator" type="operator" >
    <!-- <remap from="scan" to="base_scan"/> -->
            <remap from="cmd_vel" to="mobile_base/commands/velocity"/>
    <rosparam file="$(find nav2d_tutorials)/param/operator.yaml"/>
    <rosparam file="$(find nav2d_tutorials)/param/costmap.yaml" ns="local_map" />
</node>
<!-- Start Mapper to genreate map from laser scans -->
<node name="Mapper" pkg="nav2d_karto" type="mapper">
    <rosparam file="$(find nav2d_tutorials)/param/mapper.yaml"/>
</node>
<!-- Start the Navigator to move the robot autonomously -->
<node name="Navigator" pkg="nav2d_navigator" type="navigator">
    <rosparam file="$(find nav2d_tutorials)/param/navigator.yaml"/>
</node>
<node name="GetMap" pkg="nav2d_navigator" type="get_map_client" />
<node name="Explore" pkg="nav2d_navigator" type="explore_client" />
<node name="SetGoal" pkg="nav2d_navigator" type="set_goal_client" />
<!-- RVIZ to view the visualization -->
<node name="RVIZ" pkg="rviz" type="rviz" args=" -d $(find nav2d_tutorials)/param/tutorial3.rviz" /></launch>
There is also a problem with the rviz virtualization. currently it looks like this http://imgh.us/Screenshot_28.png.
I hope somebody is able to help me because other questions and answers in this forum didn't help me.
Edit 25. July 16: The new (error) messages are:
[ERROR] [1469487068.001244894]: You must specify at least three points for the robot footprint, reverting to previous footprint.
[ INFO] [1469487068.047285205]: Will publish desired direction on 'route' and control direction on 'desired'.
[ INFO] [1469487068.061046721]: Initializing LUT...
[ INFO] [1469487068.063258093]: ...done!
[ WARN] [1469487068.430814767]: The scan observation buffer has not been updated for 0.47 seconds, and it should be updated every 0.40 seconds.
The new tf-tree looks like this. The map and offset frame disappeared.
Here you can also find my ros.yaml file:
### TF frames #############################################
laser_frame: laser #base_laser_link
robot_frame: base_link
odometry_frame: odom
offset_frame: offset
map_frame: map
### ROS topics ############################################
map_topic: map
laser_topic: scan
### ROS services ##########################################
map_service: static_map
Edit 26. July 2016
In my config files aren't configuration regarding the footprint. The footprint error is really strange because it doen't appear at the first launch of minimal.launch, 3dsensor.launch and tutorial3.launch. At a second start of tutorial3.launch with already started 3dsensor and turtlebot this error appears. So I think it's not that bad.
I am getting senseful data from the laser which you can also see here: rviz
There were new error messages which you can find here. I also added the Parameters of 3Dsensor.launch and tutorial3.launch.
ROSWTF says that there is a problem with the not connected operator nodes but I don't know if this an important error.
Originally posted by anonymous27503 on ROS Answers with karma: 36 on 2016-07-15
Comment by Chrissi on 2016-07-15:
Sadly, your error message is not there.
Comment by anonymous27503 on 2016-07-15:
oh sorry, I added it.
Comment by anonymous27503 on 2016-07-20:
@sebastian kasperski As developer of the nav2d package maybe you can help me.
You have to set all frame-names according to your robot setup. In your tf-tree the laser frame is called "laser", so you have to set the parameter "laser_frame" in the ros.yaml parameter file from nav2d to just "laser".
Edit:
It looks like you are defining a footprint somewhere that is not correct. As the operator can only handle robot radius (as defined in costmap.yaml), you should check your yaml files and remove this definition. "rosparam list" might also be helpful.
But actually I don't think that this is really your problem. This all happens within the Operator and from your screenshot it seems to be fine. (blue and green trajectory indicator are there) Are there any other error messages? Have you visualized the /scan topic to see if it contains useful data?
In general, I would suggest to follow the tutorials step by step, so:
  1. Add Operator, check that costmap is there and the robot can move safely.
  2. Add Mapper, check that a global map is build and localization is good
  3. Add Navigator, check navigation and autonomous exploration
Originally posted by Sebastian Kasperski with karma: 1658 on 2016-07-25
Comment by anonymous27503 on 2016-07-25:
Thanks for your answer @Sebastian Kasperski. I changed the laser_frame to laser but it seems that this kills the map and offset frame. --> I added the new tf-tree to the question. I think that's the reason for not receiving a map.
Comment by anonymous27503 on 2016-07-26:
@Sebastian Kasperski I edited my question regarding your edit.
When I run rosservice call /StartMapping3 the robot drives through the room without stopping. Normally the robott should do a 360 turn as described in your tutorial.
I started rviz with the rviz config file of the gmapping demo and got a costmap as you can see in the picture.
Comment by Sebastian Kasperski on 2016-07-27:
Almost all your laser points are outside your costmap, this cannot work. You should really setup your system step by step and test everything before you continue with the next one. You cannot debug the whole system at once.
Comment by anonymous27503 on 2016-07-27:
Should I follow the 3 steps you supposed or do you mean to set up the complete robot?
Comment by Sebastian Kasperski on 2016-07-28:
I mean setting up the robot. Add all the components step be step and verify each before you go on. And if you then run into any troubles, you can ask here,
