Hi. I have written my first node - a Quaternion to euler conversion node (using the tf library). The node subscribes to geometry_msgs::Quaternion and publishes geometry_msgs::Vector3.
I now want to connect this node to the quaternion part of a pose message that's published by another node.
So i used this command:
rosrun mypkg quat_to_euler_conv quaternion:=ground_truth/pose/orientation
because pose/orientation is of type geometry_msgs::Quaternion i think this should work. but it doesn't connect. using rostopic echo and pub i can make the node work fine though.
Is it maybe not possible to remap a topic to a message part of another topic?
Originally posted by Orangelynx on ROS Answers with karma: 1 on 2016-06-21
