You just have to set your Environment Variables correctly in your case the ROS_MASTER_URI
where you specify where your PC can find the Master documented here.
So you just have to open a new Terminal Window and enter export ROS_MASTER_URI=http://mia:11311/
(mia: my ip address). In your case enter the ip address of the raspberrypi instead of mia.
Than starting RVIZ with rosrun rviz rviz
. (you also can check with rostopic list
if your topics are available now).
--- Update --
Corresponding to your comment you have also set your ROS_IP. Sorry i forgot to tell you that.
So just find out your IP-Address with
hostname -I
and export it with
export ROS_IP=192.168.xxx.xxx
So you have to do both. Setup the ROS_MASTER_URI and the ROS_IP.
Please don’t forget to set the ROS_IP at your PC and the RaspberryPi.
Originally posted by chwimmer with karma: 436 on 2016-06-06
Comment by Emilien on 2016-06-07:
thanks,
when i run rostopic list on my PC, i receive all topics but when i run rostopic bw /topic, i receive any data.
what can i do please?
i receive: Using transport "raw"
Couldn't find an AF_INET address
